Old 04-06-2011, 08:22 PM
LMB LMB is offline
Rep: 37 Posts: 52
Shrink wrap for Mold Release
Anybody know if shrink wrap will work for a mold release? I've put together a plywood box to be used as a male mold. Just looking a quick and easy way to seal the surface.
Old 04-06-2011, 09:00 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
Do a test with your resin system.
Slippery when wet.
www.cheetahcat.com
Old 04-07-2011, 04:53 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Use packing tape instead, less wrinkling.
Old 04-07-2011, 06:00 PM
LMB LMB is offline
Rep: 37 Posts: 52
Yeah, packing tape was what I started with but since it has no stretch it's difficult in the compound ( or reverse compound) corners.
Old 04-07-2011, 08:08 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
I had success with saran wrap on a small project using grp many years ago and I believe it is similar plastic. Be careful of folds and overlaps.
Hoyt
Old 04-30-2011, 08:26 PM
latman latman is offline
Rep: 14 Posts: 48
sorry i am late to post but i would brush waxed polyester onto the wood (eg surfboard filler or finish resins), then a coat of mould release wax or PVA and lay up over that surface ,you could also use car bog (bondo) against the plywood and sand that to nice curves before you paint the polyester resin on.
I think the plastic film may "float " too much ,but the weight of your laminate may hold it down ? and deal with all the wrinkles later.
Old 05-01-2011, 02:33 AM
Lurvio's Avatar
Lurvio Lurvio is offline
Mad scientist
Rep: 219 Posts: 267
I used packing wrap on my prop blade (4 x 9 cm) mold and it worked, kind of, I was using polyester resin. I would not use that material for anything larger than your palm and not anywhere near a flat surface. Maybe a thicker plastic and tape the corners. Or better yet, try book cover film that has its own adhesive.
Lurvio
Hopefully creating something useful, since 1983.
Old 05-07-2011, 09:41 PM
LMB LMB is offline
Rep: 37 Posts: 52
As a follow-up.. I tried the shrink wrap on a test piece and it did not work very well. The wrap "swelled" as it cured. It may have had to do with the heat lamp I was using to speed the cure but the combination of mild heat and solvents caused some swelling in the plastic. Ended up using packing tape and alot of release in the corners. Faired and refinished after we pulled the part. Turned out nice.
Old 05-08-2011, 04:41 PM
hoytedow's Avatar
Resistor
Originally Posted by LMB View Post
As a follow-up.. Turned out nice.
Good thing. Congratulations.
Hoyt
Will this shape release from mold? nautique210 Fiberglass and Composite Boat Building 6 08-05-2010 10:18 PM
Release agent and mold help Jacob J Fiberglass and Composite Boat Building 6 05-23-2010 06:46 AM
boat shrink wrap equipment boatprotector Materials 0 08-04-2005 04:10 PM
Shrink Wrap steveo Materials 9 10-05-2004 08:18 AM
W A R N I N G!!! All Boats With Shrink Wrap..... sharkeymarine Open Discussion: All Things Boats & Boating 0 02-17-2003 04:52 AM
