Old 01-07-2006, 09:18 PM
raymond raymond is offline
Rep: 10 Posts: 24
shower store
Does anyone know how to build a fibreglass mould at the shower store bottom to prevent water leakage? What type of resin and fibre cloth are better? Do I need to mix hardener with the resin?
Need your advice.
Raymond
Old 01-08-2006, 11:07 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
My suggestion would be to first build a plywood plug in the desired shape, then fair it smooth with router, sander and fairing compound. Wax it up good and smooth, then lay up your fibreglass overtop of that. Epoxy resins are more waterproof and a lot easier to use than the poly- or vinyl-ester types. All useable resins are two-part (ie. measure and mix a hardener). A typical layup might be: gelcoat, a light chopped mat, several layers of woven cloth or roving, then possibly a core and more cloth. I'd suggest taking out a book or two from your public library on composite construction, and trying a few small and simple parts, before you build something like a shower that involves a lot of complex curves.
Old 01-13-2006, 04:57 PM
Rep: 10 Posts: 24
Thanks Matt.
2-liter Coke Shower Inquisitor Materials 11 11-11-2005 12:03 PM
Always kick the soap to the side of the shower... Sean Herron Open Discussion: All Things Boats & Boating 9 09-25-2005 06:58 PM
255' Three-Masted Steel Barkentine for sale Yachting Marketplace 0 02-09-2005 10:35 PM
One Piece Shower nit. JohnK Materials 6 07-09-2002 04:25 PM
