Old 07-29-2008, 12:53 PM
imagineer imagineer is offline
Shorten a fiberglass truck cap
I figure this is just about the best resource for info on fiberglass repair so...
(BTW, file this one in the, "You're going to do WHAT!?!?" category)
I recently picked up a '93 Dodge Dakota for a project. I have an opportunity to pick up a near perfect $700 fiberglass cap for it for $30.
The problem, my truck has the 6'-6" bed and the cap is for an 8' bed.
I've done fiberglass repair before on a small sailboat. It's not fun, but I think I know what to expect.
I'm thinking I can take out the side windows from the cap and then cut the cap in half crossways, taking out 18" or so from the middle. Then it should just be a matter of bringing the halves together, reinforce and weld the base rails, glass it together from the inside, fill & spray gel coat the outside then modify the windows to fit the shorter opening. Simple, right?
Can anyone out there enlighten me as to what my naive ambition is overlooking?
Old 07-29-2008, 01:32 PM
Rep: 95 Posts: 462
sounds like you already know what to do
Old 07-29-2008, 05:17 PM
losttool losttool is offline
Rep: 10 Posts: 5
Cuttin up
Go for it!
Old 07-29-2008, 05:18 PM
Pylasteki Pylasteki is offline
Rep: 35 Posts: 52
Build a frame, or make your cut with it installed on the truck... Otherwise you've got a possibility of building in a twist.
Good luck.
Old 07-29-2008, 06:25 PM
the1much's Avatar
the1much the1much is offline
hippie dreams
Rep: 625 Posts: 3,931
put a 2x4 across the cap,, on the inside, against the "roof" and at the bottom where your bed connects,,,do this for both cuts,,,,before any cutting,,,,it'll keep it from twisting, or flaring out.
hehe ,,,,,Jim------>
Old 07-30-2008, 07:12 AM
Rep: 95 Posts: 462
if i was you i put a add on craigslist and try to do a swap, when you cut and rejoin the box make sure you dont over do the glass work, as down the road the repair will start to stand out, also the amount of work involved all the body work and paint, and if not done right it will always look like a homemade job, but if you have time on your hands go for it, Jimmys right about bracing the box first important to keep her square
Old 07-30-2008, 09:17 AM
tinhorn's Avatar
tinhorn tinhorn is offline
Rep: 272 Posts: 553
Most craigslist people I've dealt with are freaks and weirdos. There's a reason they can't use eBay.
I'd make the cut at the very end, not in the middle. A patch at the corner (like next to the cab) won't be as obvious as one in the middle of a large, flat panel.
Old 07-30-2008, 06:36 PM
Rep: 95 Posts: 462
guess Iam a weirdo,
Old 07-30-2008, 06:43 PM
the1much's Avatar
hippie dreams
Originally Posted by fiberglass jack View Post
guess Iam a weirdo,
i knew that was you i saw on craiglistpersonals,,,hahaha
something bout trading ya cooking utensils fer sexy boat pics,,,hehehe
Design student removing cap from hull. Where to cut??? phi784 Fiberglass and Composite Boat Building 11 08-08-2007 10:18 PM
HEI Distributor - Coil on Cap jgalt_Winner-28 DIY Marinizing 1 11-17-2006 05:52 PM
Truck diesel engines rajeshr DIY Marinizing 12 12-12-2005 08:48 PM
Shorten the keel on a Hunter 27? draig cymru Sailboats 0 12-02-2005 09:56 PM
spray-on truck liner mike Tones Fiberglass and Composite Boat Building 9 07-03-2005 07:20 AM
