Old 01-17-2011, 06:32 AM
Vulkyn's Avatar
Vulkyn Vulkyn is offline
Rep: 529 Posts: 486
Serious accident and possibility to rebuild ?
A friends boat was burned down considerably (25 meters x 6.5 meters) i have attached some pics as he wants to rebuild the boat.
My question would be how much does heat damage fiberglass? Although the bottom part was not burned badly the boat did sink and was raised. Around 1 meter above the water line was sawed off as it was severely damaged.
They did raise the boat and put some 15 tons or so in it and use it as a tugboat so it does float and can carry some load.
I am pretty concerned as he wants to use the bottom hull and rebuild the fly bridge and everything else using the existing part as a foundation.
The boat is not accessible to me at the moment he has to shipped to Egypt first so i am a bit worried that he encourages all that costs in a doomed project.
Serious accident and possibility to rebuild ?-img00211-20110115-1221.jpg  Serious accident and possibility to rebuild ?-img00214-20110115-1223.jpg  Serious accident and possibility to rebuild ?-img00219-20110116-0934.jpg
Serious accident and possibility to rebuild ?-img00220-20110116-0935.jpg  Serious accident and possibility to rebuild ?-img00225-20110116-0936.jpg
The Mummies Dummy guide to boat building stuff!!!
"All of us could take a lesson from the weather. It pays no attention to criticism."
"Learn wisdom when you can its gona help you out some day in your life"
Old 01-17-2011, 01:00 PM
Rep: 1493 Posts: 7,447
You need someone to survey the boat and a repair estimate.
Old 01-17-2011, 01:03 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Most glass composite damages considerably in a fire. Anything over 200 degrees C is suspect, if not gone.
These are project that I would never undertake without a thorough examination, perhaps even lab tests.
Old 01-17-2011, 01:14 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
Problem is it needs to be shipped to Egypt to get surveyed.
I have contacted several builders here and will await their feedback although most of them said its not a problem which to be honest worries me.
My friend doesn't want to pay shipping cost and then find out its wasted ....
There is no easy way around this but as much information gathered before shipping the better. I could ask him to ship a small section for testing though ...
Old 01-17-2011, 01:21 PM
Herman's Avatar
Resininfusion.info
Then get a surveyor to the boat!
One of my friends rebuilt a dinghy that was in a burning shed. Although it was very good possible to make it an acceptable boat again, it never got as good as new. Gelcoat all over was damaged (perhaps not a problem with your project) but also the resin had gone into a somewhat brittle state.
Old 01-17-2011, 01:25 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
Yah that seems to be the logical step, not sure if i can find some one to travel or not will keep you posted ....
Old 01-18-2011, 07:13 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
Yah no one from the companies i contacted is willing to travel to do a survey and the one that did pretty much asked for the same price as shipping the boat to Egypt :S
So guess ill ask him to send some parts of the hull for testing here and we will see how things go ....
Old 01-18-2011, 08:04 AM
Where is the boat?
Old 01-18-2011, 10:46 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Sheeet ! That wasn't such a good idea to burn it.
If you put a flat deck on it you can use it for a bass boat.
Regards
Fanie
Water ! Just gimme water !
Old 01-18-2011, 12:20 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
Its in Saudi Arabia atm.
Yes Fanie burning boats in general is not a good idea .....
Sportsfisherman accident-Jupiter Florida Doug Lord Open Discussion: All Things Boats & Boating 31 02-16-2011 08:54 PM
Captain, owner charged in ferry accident kach22i Open Discussion: All Things Boats & Boating 3 03-19-2007 08:30 PM
Use of Accident data! bigbri272 Open Discussion: All Things Boats & Boating 3 10-12-2006 11:42 PM
Crown Princess Accident Enrico Open Discussion: All Things Boats & Boating 2 07-22-2006 12:55 AM
Possibility of using new bamboo laminate. hansp77 Materials 40 05-18-2006 07:49 AM
