Old 09-09-2005, 02:46 PM
tonyg1178 tonyg1178 is offline
Tony G
Rep: 10 Posts: 4
Sea-Cast...
Has anyone tried this sea-cast system for transom replacement? Is this method reliable? And what kind of weight will it support? I have a 17 foot ski-boat that I am restoring and I want to know if this method, after ample curing time, will support a medium to large outboard and aftermarket tilt/trim unit..
Old 09-10-2005, 11:17 AM
Rep: 1397 Posts: 7,216
It will fill the gap left by rotten wood. However, it will be bonded to rot. The bond line is a structurally weak spot.
Old 09-12-2005, 09:00 AM
Tony G
Rep: 10 Posts: 4
sea-cast
when you say rot, you are talking about the rotten wood, right? If so, cant I get all of the rotten wood out?
[FONT=Lucida Sans Unicode]Tony Gregg[/FONT]
Old 09-12-2005, 09:03 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Even getting all the rotten wood out, you'll still have a potential failure plane at the joint. I have never tried the system myself but am not sure if I'd want to use it for something under so much stress, or on such a large area.
Old 09-13-2005, 02:12 AM
Rep: 2891 Posts: 8,798
There is another thread > www.boatdesign.net/forums/showthread.php?t=4287&highlight=seacast < that went over a lot of questions and may be of some help.
The company finally replied several months after the thread was started and is now reportedly to have a web site with independent testing results and specifications of product properties available on request.
I've don't have a high opinion of the stuff, mostly from their very poor customer service, when I tried to get some properties about the goo they were pouring into transoms. This stuff may be the magic bullet, but I'd be surprised. Companies with a kick butt products will be happy to tell you so, most try to prove it. This one didn't even try . . .
Old 09-13-2005, 10:03 PM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Agree with PAR, sounds suspect at best. My greatest concern is bond-strength if you can't clean and prep the inside surfaces. I've taken apart way too many "injection repairs" where the injected stuff didn't bond at all and only served to diminish that hollow sound when tapped on.
Yoke.
Here's The true Sea Sled Story,circa1985 tonydignity Boat Design 43 03-24-2011 04:36 PM
sea screamer liquidfire Fiberglass and Composite Boat Building 2 08-21-2006 05:49 AM
sea state 4 pyc23 Boat Design 1 12-13-2004 03:19 PM
I'm back to the sea! Omar Open Discussion: All Things Boats & Boating 4 09-15-2004 07:45 PM
