Old 07-28-2007, 01:26 AM
lalusiva lalusiva is offline
Rep: 10 Posts: 11
sanding the corners of parts
hello friends,
i need your help , as i ve a problem with sanding the part edges. while sanding the fibres of edges get totaly exposed . so i need to apply again primer over it. so please help me in getaway from this thread...kindly extend your valuable suggestions.
thanks
SIVA
Old 07-28-2007, 08:28 PM
the1much's Avatar
the1much the1much is offline
hippie dreams
Rep: 625 Posts: 3,931
how thick of fabric are you using? and how wet do you get it when you lay it up?
Old 07-29-2007, 01:23 PM
JRL JRL is offline
Im with stupid
Rep: 25 Posts: 83
Originally Posted by lalusiva View Post
hello friends,
thanks
SIVA
Another way to seal part edges is to apply a small amount of 5 minute epoxy to a rag and then swipe the edge of the part. Works really well.
Ideal radius on corners for Biaxial gary1 Fiberglass and Composite Boat Building 12 06-16-2007 01:00 AM
How to Fillet Corners? S Hondros Boat Design 8 08-29-2006 02:28 AM
smoothing corners and gel coating problems tropicrows Fiberglass and Composite Boat Building 3 01-17-2006 09:55 PM
mold insert to deal with negative return corners?? Pavook Fiberglass and Composite Boat Building 4 11-28-2005 12:10 PM
Gelcoat (sanding) Saeed Fiberglass and Composite Boat Building 3 02-16-2005 03:35 PM
