| sanding between layers? Hi, I am currently practising the lay up process on a square piece of wood. Before I start mt project of giberglassing a wooden banana boat. So far I have applied 4 coats of mat resin sanded it down smooth and cleaned the surface with acitone. Today I applied a coat of gel coat, this was my first time and while I tried my best to make it as smooth as possible it still looks abit rough. What do I do once this layer has hardened? Do I sand it smooth again before applying the next coat of gel? Edit/Delete Message |
The gelcoat is used only when you make your layup in a female mould. On the outer surface it makes no sense. Fairing and painting is the way to go here. And 4 times mat does not provide much strength, there should most probably be some fabric in between!?? Last edited by apex1 : 08-25-2010 at 08:21 PM. |
| You mean a fabric in between the mat layers? What would that be? Cheers |
| No, I mean a fabric instead! Mat does nearly nothing to make a strong hull. Multiaxial, or biaxial, or woven fabric is what you want after the first and possibly second layers of mat on the gelcoat. Here the mat mainly prevents the print through of the fabric pattern. This is a example of simple woven fabric: ![]() simple mat: ![]() Here a "unidirectional" oriented fabric: ![]() a coarse twill: ![]() and this shows a combination of roving and mat: ![]() bidirectional: ![]() hope that helps. Richard |
| Mat is good as first bonding layer. Structurally, woven or stiched fabrics are much better. There is no need to sand in between layers. If you are using polyester, laminating resin stays "green" (the surface sticky) so you can add more layers and get a good bond. Fairing compound and paint is the easier way to finish
__________________ Gonzo |
| Laminating resin is air inhibited.
Gel coat does not behave like paint it is thick and will not flow out like paint !! But you can help this a little by adding some laminating resin to the gel and that will make it flatten a little better and it is still sandable when it has all gone hard !! ![]() |
for finishing off you need what is called flowcoat- it's pretty much gelcoat with a wax in styrene solution added, with care you can get a good finish but it takes some work, it can be sprayed or applied by brush- tipping carfully in a few directions sequentially, to get it smooth & shiny some work with wet sanding & cutting compound- if you google surfboard building the techniques may be better described & illustrated. All the best from Jeff. |
The fibre will keep the laminated wetting out directly over it and result a little conical "tent" or air pocket, Had them many times in the past when an operator neglect to do his job properly. The give away for this is a dry white spot of mat that refuses to wet so to speak.
| May I repeat? Quote:
John, Leave all the gelcoat nonsense, you are sheathing a wooden boat, not producing a GRP boat in a mould. Tinhorn, the question was if the gelcoat layers should be sanded! There is no glass standing proud of the coat. Regards Richard |
| When doing a big transom repair, I used unwaxed gelcoat first (rolled on) then once it gelled, but before it cured fully, I knocked down any imperfections wth an orbital sander, blew, and then rolled on waxed gelcoat. Next day, I used 220 grit in the random orbit sander, followed by 600, followed by 1000 grit. Then I switched to 3M fiberglass restorer with a buffing pad, and you couldn't find the repair. Beautiful and shiny! I'm no expert, but it worked extremely well for me. -TH |
| Keep it plain and simple spraying the jell with a gun that will push the material thru it thinning it with acetone going with more mills then usual because it all gets sanded and sprayng PVA over the jell instead of using a wax addtive which is very old school . |
| sanding between layers? | John Hanafin | Boatbuilding | 3 | 08-25-2010 06:26 PM |
| Are 2 layers of wax and 2 layers of release sufficient? | Bill Brasky | Fiberglass and Composite Boat Building | 8 | 07-31-2010 02:14 AM |
| Need help with sanding | Msalvatore47 | Fiberglass and Composite Boat Building | 6 | 03-09-2010 04:17 AM |
| sanding | jbowers417 | Wooden Boat Building and Restoration | 21 | 09-20-2007 10:03 AM |
| Epoxy Layers, Sanding, and Paint | Mr V | Wooden Boat Building and Restoration | 7 | 09-18-2006 02:07 PM |
