Old 04-10-2004, 11:30 AM
ice42732 ice42732 is offline
Sailboat Restoration Help!!!
I am considering purchasing a old fiberglass flying dutchman sailboat. The owner tells me that it needs a new gelcoat. Also there are some softspot under the waterline on the bow, plus he says the bow of the boat should be beefed up. How much will all of these repairs cost, where can i get directions to do this, and how much time will it take for a unexpeirnced boater???
Old 04-10-2004, 09:48 PM
Rep: 3125 Posts: 9,399
Go down to the local sailing club (try the phone book or the web). There will be a Flying Dutchmen fleet there in all likelihood. They will give you the low down on the boat, they probably have seen it before and know of it's recent history at least. Most older 'Dutchmen need a paint job at least. They're great boats, good to learn on as they're reasonably forgiving and the race ready crew can get some good performance out of them.
Costs will depend on the location, who will do the work, how much sweat you're willing to put in and the work involved. If you are grossly inexperienced then a better example of the type (Flying Dutchmen) may be a better way to go.
Old 05-07-2004, 09:30 AM
Buckle's Avatar
Buckle Buckle is offline
Composite Engineer
Rep: 10 Posts: 83
Lots of time and effort
The hull of my 27ft motor boat was pickled with stress cracks in the gel coat. I had two opions, to burn the hull, or refair the hull. Either way its costly.
I did it myself and took 3 solid month. So go out a buy a big compressor and some good quality air tools and several hundred course DA pads. Rub the gel coat away making sure your not making any flat spots in your hull.Alteratively you could shave your hull. Once back to the glass, coat with several layers of epoxy refairing resin. Its high build stuff. They rum until smooth and very flat. So keep moving the DA. In the 3 months, I lost 2 stone in weight due to teh phyiscal nature of the work
They do a quality paint job.
Looking back on it now, Its was very hard work and is very mentally challenging as its so brain killing, Ibut m glad I did it. The resultant looks excellent. Its giving the boat a new life.
Shaun
Old 07-15-2004, 05:05 PM
kschmidt kschmidt is offline
I suggest doing it yourself. I recently got a flying dutchman. It's deck was soft as were part of the floor. In five weeks of evenings and some saturdays the boat will be sailing. (two weeks left to go)
To quote I received to repair the boat professionally was around $6000 canadian. I am guestimating that I will have spent $1500 on materials by the time I am done.
If you are interested in seeing what I have done, I have been logging my progress at: http://www.hyannispoint.com/sailing/restore_project.asp
Submersible Sailboat? uber33t Boat Design 74 01-25-2012 08:13 PM
CAE Structural support to sailboat design Giovi Boat Design 1 11-03-2007 04:01 AM
Sailboat as a powered cruiser? Bill Fish 6 Motorsailers 28 05-30-2007 05:46 PM
Please recommend sailboat plans jmwalker Wooden Boat Building and Restoration 9 08-16-2005 03:38 PM
Sailboat Restoration - Is it worth it? Yutzey Boatbuilding 0 06-10-2004 01:59 PM
