Old 10-07-2006, 07:16 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1040 Posts: 1,645
MarshallT and Kovaceski,
The ParaGlass website give the technical data in SI units and good old Imperial. This link gives SI units. http://www.parabeam.nl/Technical/Tec...t%20Metric.pdf
You will see the shear strength figures for both ranges and thicknesses of the fabrics. Certainly, the ParaTank fabrics were developed for the manufacturing above and below ground double wall storage tanks. Univar sent me the manufacturing manual for using both male and female moulds in tank construction and Paratank is available in 3, 4.5, and 6 mm, for this use. One of the primary functions is to provide a leak monitoring interstice as well as the sandwich properties.
ParaGlass, on the other hand, has been developed with boat building in mind, so the thicknesses range from 3 mm to 22mm. I have in front of me the Parabeam Industry brochure sent by Univar. I shall quote from it.
"Parabeam has been tested by many independent institutes around the world and is pending certification of Lloyds and DNV for appointed applications. Many reputed boat builders have already been using Parabeam in their production. A reference list is available upon request."
The Univar website shows Sunseeker using ParaGlass in the 105. http://www.univar.co.uk/downloads/Pa...for_yachts.pdf
I picked up on this product from the pages of the latest edition of Professional BoatBuilder. I am inclined to believe ParaGlass is very suitable for boat building, replacing PVC foam, Coremat, balsa and solid laminates.
MarshallT, by what authority do you claim that "As for the Paraglass this material was developed for double wall tanks and is not meant to be used for boat hulls. It will not be a good laminate since the tranverse fibres keeping the 2 layers seperated (sic) will not be able to handle the shear stress."?
Do you have the ASTM mechanical properties for the other cores used in boatbuilding? A prominent marine surveyor in Florida, David Pascoe, has written a number of articles about the problems associated with the incorrect uses of laminated cores in boat building, His work is on-line. http://www.yachtsurvey.com/structuralissues.htm
Kovaceski, most new ideas have their detractors. You should get your hands on fabric samples and run your own tests. I gave you a contact in Slovenia and the UK. ParaGlass features include excellent drapeability, ,superior thermal resistance, a one step process, humidity and corrosion resistance. The core and face are one (no delamination of core upon impact) and resin use can be 60% less compared with solid glass laminates.
The final decision will always be yours, but being first will give you advantages and the others are all playing "catch up". ParaGlass would give you a "Unique Selling Proposition", which is never a bad idea. But hey, I'm a salesman. I never say "What will it cost?" I always say "How much money can I earn?"
In the begining, was the Word. And the Word is?
CASH!
Pericles
Old 10-07-2006, 07:41 AM
MarshallT MarshallT is offline
Rep: 10 Posts: 11
Pericles
I suggest you lay up a hull with the Paraglass so that David Pascoe will have another article to write :-) Paraglass is a good material and will have many application on boats but the ones I have seen would not be suitable for the hull. Remember the original question was to make hulls.
"Genius may have its limitations, but stupidity is not thus handicapped." Unknown
Old 10-07-2006, 07:43 AM
Pericles's Avatar
Hello Richard,
Styrene vapours are the most dangerous and injurious factors involved with using polyester and vinylester resins. Your personal health and wellbeing is far more important than saving a few Kronar. Epoxy resins are far safer. They may cost more, but you will live longer to enjoy messing about in boats. Dave Carnell wrote this. http://www.angelfire.com/nc3/davecarnell/epoxy.html
That said, you must still take care.
SAM DEVLIN ON SAFETY
The most controversial aspect of epoxy use is the matter of safety. There is no way around it: The improper use of epoxy can be injurious and hazardous to your health. But constant vigilance and continuous care for safe and proper use will minimize the hazard. Boatbuilders using normal precautions and staying safety-minded at all times can use epoxy with the best of results while fully protecting their health. Wear safety glasses, respirators and gloves. Tyvek suits are great protection.
The strongest advice I can give you is to keep epoxy off your skin. Prolonged contact with the resin and hardener can cause an allergic reaction--sensitization--in some people. Once sensitized, the slightest contact with the resin and hardener, their fumes, or even standing dust from epoxy that hasn't fully cured can bring on a reaction.
Keep epoxy off your tools, and always wear gloves that protect wrists as well as hands. I know of three examples where boatbuilders threw caution to the wind and suffered the consequences. Two were first-time builders of boats, but one was a professional who should have known better. The common denominator was failure to use proper gloves. The professional was a reckless fool in all aspects of his life. He refused to use gloves and would plunge his hands into acetone at the end of each job to clean off half-cured resin. While using urethane paints, he would refuse to wear even the simplest dust-filter mask, let alone an organic-vapor respirator or even a fresh-air system. Predictably, he experienced lung damage from the urethane paint and spent several days spitting up blood. In addition, the exposure to the epoxy caused a rash on both wrists and his forehead that resembled a reaction to poison oak. The rash would disappear after five or six days if he stayed clear of epoxy, but as soon as he walked back into the shop, it would reappeared. In the end, he had to give up boatbuilding with epoxy altogether, and the last I heard of him, he was at work in a can factory.
Once you have epoxy on your gloves,
you WILL have an itch on your nose,
your eyes WILL need to be rubbed,
and you WILL begin to sweat
and need to wipe your brow"
-- Devlin's Law
Most gloves available to boat builders are adequate for epoxy but will never stand up to cleanup solvents such as acetone or lacquer thinner. When cleaning up, discard the thin latex gloves you used for epoxying and don heavy, solvent-proof gloves.
And then there's "Devlin's Law", a variant of Murphy's Law. After a goodly amount of experience I have identified three natural temptations that you will experience when you are working with epoxy. Once you have epoxy on your gloves, you WILL have an itch on your nose, your eyes WILL need to be rubbed, and you WILL begin to sweat and need to wipe your brow. I guarantee you'll experience these urges, and just as surely, if you succumb to temptations, you will experience some nose or eye sensitization due to epoxy exposure.
There is simply no alternative to constant vigilance: using safety gear, working as cleanly as possible, and not getting epoxy on your skin. Keeping Devlin's Law in mind, one reason for wearing a canister respirator--apart from the fumes and dust--is to keep yourself from scratching your nose.
After fifteen years of using epoxies almost daily, the only reaction I notice is a slight constriction of the throat during extended use. But when I use a respirator, I never experience the throat irritation.
Of the two epoxy components, the hardener is the most toxic. Keep this in mind, particularly when cleaning the hardener side of your epoxy dispenser. Extreme caution should also be used when sanding partially cured (green) epoxy surfaces, as may happen in the winter in an unheated shop. Always wear a respirator and protective clothing, even if it's only street clothes that are laundered daily and cover all parts of the body likely to come in contact with uncured epoxy. If you insist on keeping your beard, a full-hood, powered-respirator fresh-air system may be the only answer, since regular cartridge-type respirators will not seal properly over a beard.
The bottom line, my macho friends, is to respect these chemicals; just because the hazards are invisible does not mean they are absent.
I have seen a couple instances of almost magical acts of reverse gravity in which epoxy or its resin and hardener components splashed up into boatbuilders eyes. In each instance we had to rush the victim outside to a water hose for a lengthy flushing of his eyes. Then rush him to the emergency room where the doctor repeated the process--not something anyone would do by choice. Wear eye protection at all times. Safety glasses don't work well for me because I find them uncomfortable. And if eyeglasses are uncomfortable, at some point you'll find yourself working without them--and that's when accidents happen. Even if you don't wear eyeglasses for vision, get yourself fitted with a proper expensive set of frames with clear lenses. Spend some money on them so you won't treat them casually and wreck them. Then wear them constantly in the shop so you get used to them.
And even the protection can't be taken for granted. I've also seen a worker develop nasty looking, painful hands as a reaction to latex disposable gloves, which in his case was probably a reaction to the talcum powder in them. He was fine after he switched to non-talc gloves over soft lightweight cotton liner gloves.
Moderation is the best protection. Always shower after a work session; it will help keep your body clean and healthy. Also don't forget to launder your clothing often. Wearing the epoxy-encrusted clothes day after day just continues to expose you to uncured resin or hardener.
http://www.masepoxies.com/safety.htm
Curiously, it is possible to follow expert advice and still be harmed. I just found this. http://www.second-opinions.co.uk/fats_and_cancer.html
It seems that the only fit place to consume corn oil and vegetable oils is in the heart of marine diesels.
Pericles
Old 10-07-2006, 08:22 AM
Pericles's Avatar
MarshallT.
"but the ones I have seen would not be suitable for the hull. Remember the original question was to make hulls."
Well, I guess that says it all. The ones you have seen. But, NOT used. What fools you must think Sunseeker are.
Sunseeker 105. Core, ParaGlass 18, Skins, chopped strand 450 gr/sq. m., all glass resin laminate.
What un-utterable idiots the Sunseeker personnel are, by your opinion, to have built a $5,000,000 vessel using the incorrect materials. I wonder if they know?
I shall be building the hull of my boat using ParaGlass as part of its construction. Using Epoxy/Marineply/ParaGlass composite construction, the "U B'stard", for such is its name, will be just fine. Diesel electric water jet propulsion by OSSA Powerlite and Hamilton, an 'ybrid of the first water, ------ but that is a subject for another thread.
Pericles
Old 10-07-2006, 09:01 AM
Rep: 10 Posts: 11
Kovaceski
Here is a summary of the terminology that I think is normally used.
-Resin Injection Molding is used to make plastic parts using thermoset resins. The resin is forced into the metal mold under pressure. This is similar to injection molding which is used for thermoplastic resins
-Resin Transfer Molding also uses metal molds (male and female) and pressure is also used to inject the resin into the mold cavity. In this case however fibres are present in the mold.
-RTM Light is a less expensive method which uses fiberglass molds instead of steel. Because of the strength of the molds you cannot simply apply pressure to the resin to inject it into the mold cavity. Vacuum is used to reduce the extra pressure needed to get the resin in the mold. You can also use only vacuum.
-Vacuum Infusion (VIP) uses only one mold (normally the female mold) and uses a vacuum bag (either a throw away plastic or reusable silacone bag). It is called vacuum infusion instead of vacuum bagging because the fibres are place in the mold dry (without resin) then the vacuum is applied which will draw the resin in the mold.
-vacuum bagging usually means a bag is applied after the fibres have been hand layed with the resin. This is usually to remove air within the laminate or to apply uniform pressure on the core for bonding.
With VIP you can easily make flat panels or deck parts. If you are making a lot of different parts you have to keep in mind the extra cost of the molds for RTM light. From the sounds of it you only want to use RTM Light because you think you ar less likely to have problems. I don't have experience with RTM Light but I doubt that is the case. I think either works well when done correctly.
Leaks are only a problem with VIP if you start to infuse without making sure there are no leaks (or if you let workers play with sharp objects during the infusion :-) ) In the beginning you may spend more time looking for leaks but as the workers get better at vacuum bagging there should be fewer leaks to find. With well layed out flow channels you should not get dry spots but if you do there are techniques to fix it. The only really big problem is sudden loss of vacuum during the infusion. If that happens the part is lost. That is why you keep the knives or scissors well away from the vacuum bag. This method takes more planning than hand lay up but it is very possible to make the switch. Start with small parts and work your way up to the larger parts.
Old 10-07-2006, 09:27 AM
Rep: 10 Posts: 11
Pericles
I am sure Sunseeker did a good job but from the article you sent it does not show any application where it was used to replace a cored laminate for the hull.
Also if you are so confident that it can be used to replace a cored laminate for boat hulls then you should remove the Marinply (i.e.core) from laminate schedule on your "to be built" boat.
If I remember correctly you have recently received (maybe 3 days ago)samples from Parabeam. So perhaps you can explain to me how this makes you an expert on its use??? Oh the magic of the internet.
Brings to mind the saying "Fools Rush In........"
Old 10-07-2006, 09:28 AM
Richard Hillsid Richard Hillsid is offline
Rep: 19 Posts: 117
Hi Pericles
I have used the said 3D glass, a few rolls of it in my time and have some thoughts on it. I think the first time was in 2001 or 2002
It is a excellent idea, and when it manages to cure right with polyesters its pretty stiff.
I have used it in open moulds, 2 part moulds spaced just for it and as a stiffener added to ready laminates, made boxes out of it etc.
The stuff is not so easy to work with one might imagine and I do recommend doing many test peaces before you plan to use it in production, as I said the concept to use it in a boat is very interesting but before it is used as a structural hull part one must really test it out there are problems as water condensation into it, how to drain that etc. plus how much reinforsing it neads as it collapses when bent.
For panels its great, have used aluminium and thin ply as face. If I remember right it is used in some helicopter as a non structural wall panel.
As to Epoxy versus Polyester, the choice is not always mine to make, the customer and designer have a say too.
PS: been around all the resins since the 60’ and my hairline is not reseeding too bad so I guess I have taken care with all the fumes and dust I have swallowed and breathed.
At diaper age all new comers get messy so diaper need changing, using techniques of today we put on white overalls to protect the built part being contaminated by the worker of for PR photos.
Old 10-07-2006, 07:52 PM
Pericles's Avatar
Hello Richard,
I am using the ParaGlass as the core between layers of 6mm marine ply. The first shaped hull bottom sheets are held in position in a cradle and bonded together with epoxy and bias tape. The ParaGlass is cut to fit, epoxy resin is applied to the marine ply and the fabric draped in position inside the hull.
More epoxy is applied and the 3D fabric rises as it is infused. After the resin has cured for the correct time, the next precut panels of ply are bonded in place. All raw or exposed edges are completely sealed with tape and epoxy. In this way I can build an incredibly tough, yet lightweight, monocoque hull and superstructure without vacuum bagging. Whether I use Kevlar or bias fabric over the interior of the hull remains to be seen. The exterior will be laminated with glass cloth and epoxy in the time honoured manner.
Water condensation is not a problem as we need dry air temperatures around 22 centigrade for the epoxy. I am glad to learn your lungs are still ok. I have been working with Hydrofluoric Acid HF for 10 years now and 4 years ago there was one small incident when I inhaled the fumes.
Now I take no chances and wear face masks for every procedure. There are no second chances with HF and epoxy dust can trigger breathing spasms now. No more diving for me any more.
Pericles
Old 10-08-2006, 04:08 AM
Rep: 19 Posts: 117
This is not quite what i ment, but if you but your boat on the scale yearly you might figure it out.
  #25
Old 12-17-2006, 10:34 PM
ClarkT ClarkT is offline
Rep: 10 Posts: 96
Paraglass
Originally Posted by MarshallT View Post
FYI: If you vacuum infuse the Paraglass until you get the resin to wet out the fibres then you can release the vacuum. It will have the correct amount of resin and will spring up the same as in hand layup. This is a good technique to make heated molds (you flow hot water between the 2 layers)
Man that is a great idea! Have you had much success with that method? Do you need to take care in how the air is re-introduced to the laminate? Seems like a great way to do low temp pre-preg molds.
-ClarkT
light weight lay up nordvindcrew Fiberglass and Composite Boat Building 22 09-18-2007 08:48 AM
RTM versus VEC? Splint Fiberglass and Composite Boat Building 7 05-13-2005 06:35 AM
chopper gun vs. hand laid Fiberglass and Composite Boat Building 13 06-29-2004 08:46 AM
Want to make a glass Raceboat...But... what lay up????? RT's Fiberglass and Composite Boat Building 2 06-17-2004 11:10 AM
Second Hand Software guest12020101217 Software 1 09-12-2003 09:34 PM
