| Rotatable boat formwork - any ideas? I am trying to settle on a design for a framework to build my 28footer on, so that I can rotate the hull on demand for laying up fibreglass, painting etc. Has anyone seen or built something like this before ? |
| Two ring frames made out of steel tube with a locking device work well, many have been built doing this sort of thing
| Sure, a boat rotisserie is real convenient. The only complicated part is the bracket to secure the stem and transom to the "axle". It was easy for me, with a welded aluminum 20', just hang the whole thing from two come-alongs. A friend in Maine built a wooden 34 footer on a rotisserie. As I recall, his wife made him use a floor-mounted rig, rather than hanging it from the ceiling joists, as they lived above the shop. |
| The rotating bit (whatever i end up using) would be great to be on a trailer. I imagine i will need to have some sort of stabilizing legs for levelness as well as stability if I build on some sort of wheeled platform. The need for a trailer is to be able to cart the boat around to tradespeople for painting, electrical, eviction from sheds etc etc |
| Something like this?
__________________ Chris Tucker Marine Design Your Boat Your Way. www.ctmd.com.au |
| Hi Chris Thanks for the picture - that helps a lot. I can see that that is a mould, but the principle looks great. I will need access to the hull exterior of course, but if I hung an internal space frame girder off the top of the "circle", I would get the result I needed. Many Thanks |
| Rotatable Hull(ROH) Multifoiler | Doug Lord | Multihulls | 9 | 12-15-2008 01:43 AM |
| Need ideas with trout research mini-boat design | tjxtreme | Boatbuilding | 12 | 12-03-2007 07:22 PM |
| human powered boat stability ideas | gregk | Boat Design | 10 | 11-19-2007 10:01 AM |
| budget custom pontoon boat ideas | no1likesme | Boat Design | 0 | 06-21-2006 10:30 PM |
| Building small pontoon boat. Ideas? | drose | Boat Design | 1 | 07-21-2005 06:02 PM |
