Old 10-10-2006, 03:49 PM
grp.boat grp.boat is offline
Rep: 10 Posts: 46
ripples in hull
I am about to take a new mould off one of our existing hulls (to which i own the rights and design). There have always been slight ripples along the sides of the hull runnng downward. The hull is of simulation clinker so i know it may be a bit easier to do than if it were totally flat. I have done a similar type of work before but only using body filler(bondo) and lots of rubbing down. Is there an easier and correct way of doing this?
Old 10-10-2006, 04:28 PM
Rep: 527 Posts: 792
If there were any true shortcuts to fairing, you could patent it and make a fortune
Jimbo
Old 10-11-2006, 09:49 AM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
Now is the time to fix it. Fair out the imperfections on the hull/plug
www.boatbuildercentral.com
Old 10-11-2006, 12:13 PM
Rep: 10 Posts: 46
whats the best filler to use? Durabuild? Bodyfiller?
Old 10-12-2006, 05:27 PM
Buckle's Avatar
Buckle Buckle is offline
Composite Engineer
Rep: 10 Posts: 83
the quickest method of fairing is to use the longest board possible. But that depends on the wavelength of the deviation of ripples and labour.
A long board is typically 4 to 6 foot long. A short board tyically 2" long. You may thing your fairing a hull with a short board but often you are just rubbing the surface without removing the high points. Your long board needs to be longer that the length length your trying to remove.
Durabuild is a tried and tested fairing product.
Hope this helps.
Buckle
(Composite Engineer)
Buckle's Avatar
Composite Engineer
Rep: 10 Posts: 83
mexicans are a very cheap labour source.
Buckle
Hull ripples? cammo Fiberglass and Composite Boat Building 3 02-24-2006 10:25 PM
differences between nitro hull and vee pad hull riveramunizaga Boat Design 4 05-24-2005 11:27 PM
what is faster a flat boat hull or a vee pad hull riveramunizaga Boat Design 24 05-24-2005 03:18 PM
hull boat redesigns (hull pad project) riveramunizaga Boat Design 9 05-12-2005 09:35 PM
Hull or hull & deck broke apart during 40-50 mph turn Jeff Powerboats 1 07-09-2002 01:27 AM
