Old 07-18-2005, 11:45 AM
Jeff Therrell Jeff Therrell is offline
Rep: 23 Posts: 37
RIB Tube maker
We are looking for someone to build the tube for our 17' ridged inflatable boat .We are located in Hickory NC.We want the tube to be welded not glued.
Thanks
Jeff Therrell 828-313-0874
Old 08-02-2005, 01:30 AM
wet-foot wet-foot is offline
Rep: 10 Posts: 175
tube for your 17 footer
wing.com ........ they put out a really nice welded tube. Located in CA.
Old 08-02-2005, 03:53 PM
Rep: 23 Posts: 37
Thanks,we're getting a quote from them now.
Old 08-03-2005, 12:56 AM
Rep: 10 Posts: 175
wing tube set
Good choice indeed!!!!!!! they started out as whitewater boat builders and now do strictly RIBS. Strong and well made, you won't be disapointed. Are you starting a boat company?
Old 04-01-2006, 09:16 PM
brian eiland's Avatar
Rep: 1503 Posts: 2,648
Tube Choice?
Who did you finally chose to build your RIB tube??
RunningTideYachts.com
Distinctive Expedition Yachts
Old 04-02-2006, 09:45 AM
Rep: 23 Posts: 37
We had a company from Houstin TX make the tube.The tube is made of urethane and has seperate removeable bladders inside.You can see the boat at www.hydroeye.com
Thanks, Jeff Therrell
Old 04-02-2006, 03:27 PM
Rep: 10 Posts: 175
Inflatable tri
Neat boat, looks very beamy!!!
So where do I go for a test run, do you offer a trailer package?
I would probably look for a Yamaha but would consider the e-tec, if priced right.
Very nice job!!!!!!!
Old 04-03-2006, 12:12 AM
Wellydeckhand's Avatar
Wellydeckhand Wellydeckhand is offline
Previous Member
Rep: 36 Posts: 1,403
The hull seem suitable for shallow river but would it withstand small storm or as a crew boat for offshore transport.................. this hydroeyes?
Old 04-03-2006, 07:48 AM
Rep: 23 Posts: 37
Wet-foot,The reason for the E-TEC was it was 74#'s lighter than the Yamaha.
Come on down to the beautiful mountains of North Carolina anytime and we will ride.
The boat was built for the ocean but we are demoing it to the NC swiftwater rescue team next week
ThanksJeff Therrell
Old 04-03-2006, 09:09 AM
Rep: 10 Posts: 175
E-tec? nice to see such a large group praising these motors, perhaps I'll give them another go! Are the boats going as a package, have you established pricing?
Old 04-03-2006, 11:01 AM
Are the bladders made of urethane, or the outer casing, or both? If the "tube" is urethane, then what are the bladders made of?
You might check your private message box as well as I sent you a message there also.
Old 04-04-2006, 01:59 PM
ThanksJeff Therrell
Have you had it out in the ocean?
Will your demo be in the ocean?
What date for the demo?
What max chop would you guess you've had it in?
What max load aboard in that chop condition?
Courious, as I have some backgrd in multihulls, Brian
Old 04-04-2006, 07:25 PM
Rep: 23 Posts: 37
Brian,Jay tested it for 2 months in the ocean off Miami,he had it in 10'seas in the gulf stream.
Jay said he e-mailed you today,he is the one that designed it and owns the company,he can explain every detail.If you didn't get his e-mail give him a call the number is on his website.I am the one that builds the boat for him,we both live in hickory and had to go all the way to Alabama to meet and I was building racing parts at the time he needed some help.To make a long story short I sold my business and went to work for him and it has made for a very good relationship.He is a very smart and good person.Give him a call you will enioy talking to him.
Thanks Jeff Therrell
Old 04-04-2006, 10:14 PM
Rep: 10 Posts: 175
What is the logic behind a bladder? Seems to make it a bit more complex and adds extra weight. I really like the wide beam even though it would take more air to self right, if so equipped! Nice looking craft, expect you will do very well with it.
Old 04-05-2006, 08:16 PM
Rep: 23 Posts: 37
The reason for the bladders is that if you puncture one you could replace it while on the water in just a few minutes.There are 5 bladders in this boat the 4 side bladders are all the same and the front one is curved.
Thanks for the complement.
Thanks
Jeff Therrell
"extruded" carbon tube? Doug Lord Fiberglass and Composite Boat Building 1 04-28-2005 06:43 PM
Do You have a RIB Boat mold? Erik Asnyg Boat Molds 2 05-27-2004 03:33 PM
rib help billboat10 Powerboats 1 05-16-2004 12:42 AM
RIB Design help bobber Powerboats 2 05-10-2004 11:43 AM
8M Rib Project GAVIN POWER Boat Design 0 01-31-2004 02:32 PM
