Closed Thread
Old 07-12-2009, 10:06 PM
CapeCodAngler CapeCodAngler is offline
Rep: 17 Posts: 17
Restoration Project: Adding Weight to Level Trim
I have an older 19' fiberglass skiff (Midland) that I am restoring with the help of a professional boat builder. We have added a new outboard (Honda 90) and a console (battery location) and under seat gas tank (midship). We took the boat to a local pond and trial floated it today. After moving around the gas tank (full) and console, it seems that we need to add weight to the bow area to get the boat level. We are thinking of adding lead weight in the bilge area in the bow.
The original specs indicate that it can handle the weight of the Honda.
Anyone else deal with a similar problem" Suggestions?
Thank-you
Old 07-19-2009, 08:42 AM
tunnels tunnels is offline
old one !
Rep: 343 Posts: 1,520
Thank-you
Its not a good idea using lead weight to balance as in a rought sea the bow will not lift and you will end up with a boat that is wet and a real dog !!lus it dangerous as without quick bow lift you could have a wave come over the front and filling the boat with tons of water , once one wave comes in ,the next and the next untill it is full and sinking !! dont do it !!
At rest the bow should look up anyway . its at speed you need to use the power trim to do your leveling .
Boat on the water with one person in the driving possition should has approx 3 to 4 Dregress of angle of attack or slightly more when planing at about 1/2 to 3/4 throttle .
Old 07-25-2009, 01:47 PM
Rep: 1397 Posts: 7,216
They make hot babes for bow ballast
Old 07-25-2009, 06:51 PM
apex1
Post some application form please! .pdf or .doc preferred!
Old 02-14-2010, 07:15 PM
Rep: 17 Posts: 17
Thank-You
Thank-you for your suggestions. My wife would not let me use the "hot babes ballast solution", so I sold the boat.
A appreciate your help
Old 02-14-2010, 07:38 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Mad Scientist
Rep: 1786 Posts: 2,987
The 2 happiest days in a man's life; the day he buys a boat and the day he sells it.
Hoyt
Lighting is very selective and will not strike crap. Wynand N
http://www.genocidewatch.org/southafrica.html http://www.saabc.net/
Old 02-14-2010, 07:45 PM
Rep: 17 Posts: 17
Time to End This Thread
QED...That's all folks
Closed Thread
When adding a 2nd level to a pontoon... VanDamage007 Stability 10 08-11-2009 08:57 PM
Flying Dutchman Restoration Project Andy Wooden Boat Building and Restoration 13 05-02-2007 04:52 PM
Adding weight to daysailer centerboard techcontrol Sailboats 11 10-16-2006 08:23 AM
Searching for restoration project sronicker Sailboats 4 06-28-2006 06:31 PM
New Restoration Project Questions IHTFP Fiberglass and Composite Boat Building 4 05-18-2005 01:49 AM
