| resin quantity? help I am building a hardtop approx 8 by 11ft devinicell core with 1 layer of mat and 1 layer of glass cloth on top and bottom. I want to how much resin I will need. jt |
| my guess would be a 20L(5gal) pail,,,with some to spare. |
| John, For hand lay-up a glass to resin ratio of 0.33 is a safe (conservative) aim. Knowing this you have to weigh the cloth and calculate the amount of resin needed. Make some extra, just to be sure. If you don't feel confident, go to your local GRP-shop, they'll be glad to help. Good luck.
__________________ Dutch Peter “The opinion of the majority is not necessarily correct” – Yi Qing Cui |
| There is a formula SP use Resin harder mix required (grams) = AxNxWfxRC x1.5 (1-RC) Where A = area of laminate (sq.m) N = number of plies Wf = fibre weight of each plie (g/sq.m) RC = resin content by weight Typical R.C.’s for hand layup manufacturing are: Glass 0.46 Carbon - 0.55 Aramid - 0.61 resin has approx density of 1.1g/cm3 Mojo |
| Resin infusion and resin content | sorenfdk | Fiberglass and Composite Boat Building | 23 | 05-17-2011 08:02 AM |
| Price of Crude oil Versus Resin | RThompson | Boat Design | 4 | 06-03-2005 11:31 PM |
| Absorbtion of Polyester resin by carbon uni | Doc Martin | Fiberglass and Composite Boat Building | 11 | 04-18-2005 02:29 PM |
| how much resin? | Lew Morris | Materials | 3 | 06-22-2004 07:13 AM |
| Polester Resin | Memphis Mike | Materials | 6 | 08-12-2001 11:38 PM |
