Old 01-21-2012, 02:03 PM
cergun cergun is offline
Rep: 10 Posts: 2
resin impragnator/wetout machine
Does anyone know of any plans or a site that describes a 'homemade' impregnator?
Old 01-21-2012, 04:26 PM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,025
check the principles of opperation & adapt your available materials & skills- http://www.atlcomposites.com.au/file...bat_junior.pdf these can be made small & neat for taping jobs, heres one that my Dad built after looking at a Pro Set one....http://www.boatdesign.net/gallery/sh...1/ppuser/12438 pre wetting your fabric on a plastic covered table is probably the simplest way, lay down about 6 layers of builders plastic on the table so if the resin gets too sticky you can flick off a layer, go to town with a bucket & roller & roll the fabric onto a piece of 90 or 100 mm pvc storm pipe for transport to the job.
Old 01-21-2012, 10:41 PM
SamSam SamSam is offline
Rep: 502 Posts: 1,682
Fabrics can follow several different paths on each model to accomodate a range of fabric weights.
configuration for very light fabrics
configuration for light and medium fabrics
configuration for heavy fabrics
The weight of the fabric and the viscosity of the resin system determine the throughput of the machine. For example, a 24" wide, 9 oz. unidirectional S glass can be wet out at about 15 feet per minute, with a resin content of 40 to 45% by weight using the PRO-SET Epoxy 145/229 combination.
http://www.prosetepoxy.com/process_equipment.html
Here's another site with a downloadable operators manual...
http://www.phoenixequipment.com/satu...pregnator.html
Old 01-22-2012, 03:36 AM
Rep: 10 Posts: 2
Thanks for the reply,but I already checked these adresses, the problem is how to move and fix the rollers very accuratly? I will use 200-300 and 400 gr UD carbon and 300-400 gr X carbon so rollers distance should be from 0,1 to 1mm (if I use thicker clothes in the future)
I am thinking to use aluminum rollers and cover the pot with teflon, I will use sika low viscozity epoxy(250 mpas), I think I have to try and see for having an idea about the resine/fiber ratio? Here I have lathe and cnc facilities and I will start to 53ft sailboat from carbon and if I can make one machine that will significantly reduce my workhours but also I am scaring to spend my time and money for having an unusefull machine ..
Old 01-22-2012, 01:48 PM
If you want the nip rollers to squeeze out the resin to a precise ratio of resin/glass, they would have to be very accurate. If you are only approximating resin/glass ratios of hand layup but are looking for the speed of wetting out that an impregnator will give you, you might try and use cheap rollers with a squeegee type arrangement to scrape off excess resin.
Here's a homemade impregnator of some sort described, you have to join to see the pictures...
http://www.compositescentral.com/showthread.php?t=6620
Old 01-24-2012, 12:46 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
For those that do not want to subscribe (although it is a very good forum) here is the PDF as well:
http://www.brandscomposiet.nl/produc...inventaris.pdf
If anyone needs more pictures, please PM me your mail address.
Resin infusion and resin content sorenfdk Fiberglass and Composite Boat Building 23 05-17-2011 07:02 AM
Epoxy resin over poly resin ??? lobsterman Fiberglass and Composite Boat Building 5 05-15-2011 07:37 PM
magnum resin machine mc22 Marketplace 1 12-08-2010 10:53 AM
Triaxial mat wetout jimrudholm Fiberglass and Composite Boat Building 8 05-15-2010 03:07 PM
Strange epoxy wetout rwatson Fiberglass and Composite Boat Building 49 11-14-2007 01:50 AM
