Old 07-08-2006, 10:53 AM
micag micag is offline
Rep: 10 Posts: 3
resetting sole
I cut the sole out to repair stringers etc. There was coarse sawdust filler glueing it down. Mostly failed. Should I use similar( with epoxy) or is there a better way. 21 Romany Fisherman 1969
Old 07-08-2006, 01:36 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Hi micag,
If the old stuff was mostly failed, then redoing it the same way will probably lead to another failure. Some photos of the old structure might help everyone here to evaluate your problem and find a better solution. Do you have any you could post?
Old 07-08-2006, 10:08 PM
Rep: 10 Posts: 3
more info
I think the problem was two fold, the upright plywood stringers were broken from the tabs attached to the hull, and the bedding compound had broken from the sole. I reglued all of the broken free tabs with epoxy.
Also the stringers running the length under the sole were poorly fiberglassed, leaving the area above them weak, causing crunchy walking directly above the stringers. I remedied that problem by turning the sole upside down and pumping expoxy resin in all the voids running along side the stringers.
I am ready to reinstall the sole and need to reattach it to the top of the stringers.
Cockpit Sole above Waterline height? Seafarer24 Sailboats 8 06-25-2006 12:48 PM
Sole tie in?? man5 Fiberglass and Composite Boat Building 7 04-16-2006 07:12 PM
ideas for deck/sole JR-Shine Materials 8 12-03-2005 05:57 AM
Soundproof cabin sole Willallison Materials 3 10-03-2005 08:01 PM
Under sole fuel tank Arko Wooden Boat Building and Restoration 20 02-27-2004 08:45 PM
