Old 06-06-2004, 12:21 PM
gbaaron gbaaron is offline
Rep: 10 Posts: 23
Replacing stringer, bulkheads, floor
I'm replacing the sringers & bulkheads on a 20' baja. any tips & info would be much appreciated. I have heard that I should replace one stringer at a time to aviod hull distortion. Could I replace them all at once if I build a jig for the hull to set in. THANKS.
Old 12-10-2004, 03:53 PM
Rep: 66 Posts: 640
Read up on the subject before you start.
If the building jig supports about every other frame, yes you can do it in one go. But two or three at the time at alternate positions is safer.
Dutch Peter
Old 12-10-2004, 08:11 PM
tja tja is offline
Rep: 11 Posts: 125
tja
I might be wrong but I believe that Baja cores the bottoms with balsa core and then puts the stringers on top of that atleast that is how they used to build them just like Checkmate which is just a few miles from Baja. Baja was bought out by another manufacturer a while back so they may have changed how there built. Ther is another fellow on this forum that lives in the same town as Baja and i'm sura he will know more then i do. If the bottom is cored with balsa and it's still good i see no reason why you couldn't replace them all at once. Just leave it on the trailer, Tom.
Old 12-11-2004, 12:40 PM
RealityBoatCo's Avatar
RealityBoatCo RealityBoatCo is offline
Rep: 10 Posts: 93
Yes you can do it all at once. I just would not wait too long between removal and replacement. Remove them one weekend and then replace them by the next and you'll be fine.
Wood to use replacing keel stringer painter Materials 13 04-16-2010 12:14 PM
Confused about floor and stringer work! 14boatjunky Fiberglass and Composite Boat Building 1 08-22-2005 05:15 PM
Yet another stringer repair post... TBarCYa Fiberglass and Composite Boat Building 16 09-01-2004 05:44 AM
Restoring an old boat, starting with the floor. jsass Boatbuilding 7 06-24-2004 09:56 PM
Replacing floor & stringers gbaaron Powerboats 4 06-15-2004 09:26 PM
