Old 09-11-2008, 11:52 PM
seagull369 seagull369 is offline
Rep: 10 Posts: 9
Repairing floor stringers
Evening everyone. I just signed up to the site after reading some impressive posts here, and was hoping a few of you wouldnt mind taking the time to read about a problem I have of my own and some solutions I've thought up.
I've just finished ripping out the rotted floor/ wet foam/ and rotted stringers out a my 19' mid 80's Bayliner Cuddy. I plan on keeping this boat a long time so I'd like whatever I material I use to rebuild them to be as bulletproof as I can get them. FOr me, this pretty much excludes using wood of any kind, or foam core even.
Stringers:
There are channels (of sorts) left by the wood I've removed from the stringers. I thought about using a polyesther reinforced filler (bondo-glass or bondo-hair, for example) to fill them in and level off with the surrounding areas. The wood that was originally in there only measured about 3/4" X 3/4" in most sections, so the amount of filler I'd need isnt tremendous (they sell the stuff in gallon cans too). I tested out a cured piece of this stuff in the above dimensions and, though I found it to be pretty darn stiff, I don't know enough if I'm asking for trouble by using it. (I should mention there are 6 stringers althogether in the boat: 4 that ran the entire length and 2 shorter ones that run about half the length).
Floor supports:
As for the floor supports, I've thought of using cellular pvc trimboard. This stuff is similar to wood, very light and will not rot, but on the downside it's not meant to be load bearing. In an attempt to make it that way, I thought about encapsulating it in fiberglass material (cloth/ matt, roving or bi-ax) and resin (epoxy or polyesther). I've already tested a small piece of the pvc with a mixed batch of polyester resin and the pvc help up well. Another good thing about Cellular pvc is it can be screwed into just like plywood, so I could easily secure whatever floor that will go above it without too much of a concern. .
Floor:
As for the floor itself, I could use pvc again (I can get it in 4'X10'X3/8" sheets) and laminate it again with one of the cloths/ resins. Or,,,, I thought I could just skip the pvc and make it all fiberglass-- (throwing a plastic liner over a plywood template, then start laying on top, for example).
So that's about it. Does this all sound crazy or does it actually have a chance? I've tried to talk to some local marinas in the area about this (or even the standard way to make these repairs) and frankly no one really seems knowlegeable enough to tell me much of anything. I'd be eternally grateful as to any help you could provide.
Thanks for reading,.
Old 09-12-2008, 05:37 AM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
first off,,, you dont want to fill your stringers with bondo.,,,wood or foam is BEST,,remember, even tho its a stringer, it still needs to FLEX. and it will or your boat will do it AROUND your stringer====not good.the "filler,,wood/foam" is there to fill the empty space and give a little rigidity,,but still flexible.
pvc stuff?,, couldnt tell ya nothing about it,,, sounds like plastic wood,,,,, which is useless when glassing. fiberglass wont stick to it,,,, ya i know you can get a piece of glass to KINDA stick to plastic,, but the very first flex of your boat will change your mind on that.
and theres NOTHING wrong with wood floors,, as long as you encapsulate them in resin (epoxy),, then glass over. and as long as you dont put no "sissy-momma" rug in it ,,hehe
hehe ,,,,,Jim------>
Old 09-12-2008, 11:20 AM
mongo75's Avatar
mongo75 mongo75 is offline
Rep: 95 Posts: 262
Yeah what Jim said, minus the 50 commas LOL. I've rebuilt 3 boats and I'm never scared to use wood, because as long as it's properly encapsulated, it'll last a LONG time. On my last boat, a 25' 1974 Bayliner Saratoga Express, I had to rebuild the entire cockpit (about 7x8') and used plywood exclusively because never had any actual stringers, just a plywood grid from the factory??? But it worked great, and she held up fine (unintentionally) jumping 3-4 waves on the ocean. On my current boat, a 25' 1968 Luhrs (can you tell my buget by the year of my boat hehe) I ripped out the flimsy 3/4" ply stringers, and replaced them with 15' of double plied 3/4" ply held togetherwith epoxy and matt. I then tabbed that to the hull with 6" glass tape, and then covered the whole mess with roving on the sides, 6" tape over the top, and then finally one layer of 8oz cloth, and the damn things are SOLID. Good luck!
Danny
Old 09-13-2008, 03:46 AM
Rep: 10 Posts: 9
Thanks guys for replying. Guess I was under the assumption that sturdier the stringers were, the better she'd hold up. Good to know that isnt always the case.
As far as the cellular PVC stuff I mentioned, yea, it is plastic but I did fing -glass adhesion to be pretty good, AS LONG as the stuff was seriously scuffed up prior (I used 60 grit on a belt sander). Whether it holds up under the rough and tumble of a marine environment is certainly something to think about and I'll definitely be testing it out more rigourously before I decide to go with it.
One other material I found online (on this site and elsewhere) is this Nida-Core stuff. I'm sure most of you have heard of it. Supposedly good for stringers, floor and bulkheads as long as it's glassed up properly. I'm still gathering info. on it if it'll meet my needs, tho. An interesting idea concerning the stringers was to use regular old PVC plumbing pipe in there- specifically cutting the pipe in half lengthwise, throwing one of the halves in the stringer channel halfmoon side down, then glassing over with fiberglass.
I know some of you are probably thinking all these 'alternatives' are the wrong way to go about this (and I hate to sound like a sourpuss by passing it up), but I've just had my fill of dealing with wood and the rot that always seems to come with it.
Old 09-13-2008, 08:14 AM
the1much's Avatar
huh? hehe ;)
the ONLY way for wood to get wet in a stringer,, is if you didnt glass right
Old 09-13-2008, 08:44 AM
BHOFM BHOFM is offline
Rep: 247 Posts: 458
Forget the PVC stuff, it is for plumbing, not serious boat
repair. Even scuffed, when it moves the glass will release
after a time.
Keeping the inside clean and dry as possible will be the
trick to make sure your repair lasts a long time!
Is it a trailer or slip kept boat?
Old 09-13-2008, 01:35 PM
Rep: 10 Posts: 9
Hi, I keep the boat on a trailer.
Old 09-13-2008, 02:09 PM
the1much's Avatar
huh? hehe ;)
ya if the stuff is plastic it will never bond right,, it flex's at a different # of force and BEFORE the glass will. ( dont ask how i know ) it will feel like it does,,but,, take a 2x2 sheet of that stuff and a 2x2 sheet of glass, overlap say 6" , when you resin,, resin the whole piece of glass. after its cured, put 1 end of the plastic in a vise,,now grab the other end of the glass, and bend. WEAR GLASSES.. there is NO application that i have ever heard of that will bond glass to plastic. ( talking bout that, i owe 1 of my old bosses a plastic "coleman" canoe,,,WOW what a ride down those rapids hehe )
Old 09-13-2008, 07:14 PM
Rep: 2891 Posts: 8,798
Yep, everyone's right on the bondo or other type of surfacing filler in the stringers. Replace with a structural element, such as closed cell, high density foam, good wood, honeycomb core, or other "core" material.
As you mentioned in your original posting, those PVC planks are not load bearing and there's a reason why. They break, deflect dramatically under load, can't even support their own weight in longer lengths and generally are unsuitable for structural pieces.
PVC will shed anything other then PVC that's been "welded" to it. It doesn't like paint, chemicals, heat, cold, UV, all of the common adhesives, is brittle, doesn't hold fasteners and the list is extensive.
Old 09-13-2008, 11:31 PM
naturewaterboy naturewaterboy is offline
Steel Drum Tuner
Rep: 10 Posts: 210
You may want to see if Bayliner will tell you if the wood is even necessary. I cut open the stringers on my Silverton and went spent a lot of time and money before I thought to email Silverton. They emailed back that the wood was totally unnecessary to replace. It was only used as a form to lay the glass up on.
Wherever you go, there you are...
Old 09-14-2008, 07:42 AM
the1much's Avatar
huh? hehe ;)
their FULL of sh!t ,,,, and dont ask bayliner nothing,,, they cant even build a boat right,, why would someone ask their opinion?
Old 09-14-2008, 08:05 AM
missinginaction missinginaction is offline
Rep: 361 Posts: 297
Naturewaterboy is right. You don't have to take a manufacturers word for it, read Dave Gerrs book "The Elements of Boat Strength".
I just posted a couple of photos in the post right before this one "bulkhead connection - cored construction". FWIW, you can see what I did there. I'm doing my first restoration, but I did my homework before I started. I don't pretend to know nearly as much as some of the pro's here. That said, the stringers that I made up are extremely strong due to the fiberglass, not the foam core. The core of a stringer that is covered in a properly thick fiberglass laminate (there are formulas in Mr. Gerrs book that will show you how thick your laminate should be for various engine sizes) carries NONE of the loads. As Mr. Gerr states in his book, you could (and some manufacturers have) laid up stringers over foam cores and then dissolved the foam leaving a hollow core. The fiberglass does all the load carrying. That is why it's so important to learn how to laminate properly and radius your corners to spread loads, etc...
Regards,
MIA
Old 09-14-2008, 08:25 AM
the1much's Avatar
huh? hehe ;)
Regards,
MIA
ANYONE that says its o.k. to dissolve the foam inside a stringer should be shot!
O.k. regulars,,,,,here comes the soda can!!!
take a freakin soda can, empty it,,,,now step on the damned thing,, what happens????? now take an empty can, fill it with sand, all tha way,,,,now step onit,,,what happened????
a hollow stringer is like having a freakin boat made of paper! end of story!
Old 09-14-2008, 09:04 AM
Rep: 361 Posts: 297
Shooting someone seems a little extreme don't you think? (I couldn't resist)
If the soda can analogy is true........consider this.....
How can the wing of a 747 hold up hundreds of tons?
FWIW, Gerr didn't recommend dissolving the stringer cores, he just mentioned that it had been done. He didn't recommend it because if the stringer developed a pin hole (in the laminate) water would enter and you'd end up with long water tanks in the bottom of your boat. This could cause problems, especially in cold climates. Should the water freeze and expand....well, it wouldn't be good. Nevertheless the skin carries the load.
Now where's my flack vest?
MIA
Old 09-14-2008, 09:21 AM
the1much's Avatar
huh? hehe ;)
even SUGGESTING it is a "shootable" offense. and i know people that have built boats that floated for about a month,,,so if they did it should i put it in my book? people have done ALOT of things,,, doesnt mean its right. and how does that wing stay up? IT HAS "STUDS" IN IT,,,IE: SOLID STRINGERS.and a wing of a plane doesnt keep the plane together like stringers do in a boat.
what about your motor mounts to that hallow stringer?,, that should last about a week.
and theres way bigger problems with hallow stringers then it becoming a water tank.
Advice on keeping my fiberglass hull true when re glassing stringers & floor back in. craigathome Fiberglass and Composite Boat Building 9 03-01-2006 10:46 AM
Anybody have info on repairing delaminated stringers? Starquesttsi Fiberglass and Composite Boat Building 5 12-16-2005 07:28 AM
Stringers in, now the floor Ok J Fiberglass and Composite Boat Building 2 06-23-2005 01:10 PM
Replacing floor & stringers gbaaron Powerboats 4 06-15-2004 09:26 PM
