Old 09-05-2006, 07:49 AM
fishweed fishweed is offline
Rep: 10 Posts: 45
repairing the deck with poly or epoxy?
I have been on a few threads about stringers, and I do appreciate the input, most of you guys have forgot more about resins than I will know, I bought a fiberglass motorsailer that has a wood topsides and deck but a fiberglass hull, the hull is in good shape, but I have had to replace the aft deck and the port and starboard decks around the wheel house, the boat was constructed with mahogoney beams and plywood, I used treated wood for the beams and fir plywood as the replacement wood for the decks, what I need to know is when I reglass the decks, the aft deck,and the topsides can I used polyester because of the cost and seal with epoxy later I attached the 2x6 treated wood to the fiberglass hull with 7 inch ss 1/4 bolts and sealed with 5200 and then installed the fir plywood to the deck
Old 09-05-2006, 07:53 AM
Figgy's Avatar
Figgy Figgy is offline
Rep: 88 Posts: 315
Epoxy it. Polyester will cost you in the end anyways. I know it hurts, but use epoxy.
Imagination is more important than knowledge.
-Einstein
Old 09-05-2006, 11:31 AM
buckknekkid's Avatar
buckknekkid buckknekkid is offline
Rep: 37 Posts: 345
EPOXY, its actually cheaper in the long run.
Can anyone spare any gas today for a hamburger on Friday ???
Old 09-06-2006, 11:05 PM
jimslade jimslade is offline
Rep: 14 Posts: 304
Vinylester poly maybe a compromise.
Old 09-07-2006, 05:56 AM
Figgy's Avatar
Rep: 88 Posts: 315
Suck it up my man, epoxy. Would we do you wrong? Do it right the first time so you can get to the other projects on your list. Trust us, you WANT to use epoxy.
-Figgy
-Einstein
Old 09-07-2006, 09:38 AM
Rep: 10 Posts: 45
when you are right you are right
Epoxy it is, thanks fellows, after I finish the glassing I will either try to make or buy a mast, but that is another day, are there any good web sites to buy epoxy?
Mark
epoxy and poly? COLD-EH' Fiberglass and Composite Boat Building 9 12-26-2005 07:00 PM
What type of resin to use? epoxy or poly. for this hole in Bow? J-Bird Fiberglass and Composite Boat Building 4 12-25-2005 12:21 PM
Fasteners as well as epoxy at sheer/deck joint? bjl_sailor Wooden Boat Building and Restoration 3 05-26-2005 08:47 PM
poly vs epoxy manufactured to repair LKJR Fiberglass and Composite Boat Building 4 08-24-2004 03:56 PM
Teak deck laid in epoxy Guest Boatbuilding 5 07-09-2003 05:21 AM
