| Repacing Stringers-Type of Glass? I am in the middle of repalceing the stringers and floor in and old fiberglass skipjack. I have the stringers cut and fit, what laminate sched. would you use? The stringers are- one center, 2"X8"X 21', and two, 2x4x10 wood...... |
| Most of the time 2 mat and 2 roving is enough. This must be a 21' plus boat so you could add another layer of each if you wanted to. |
| 2 layers of 1810 glass. |
Doublebias tape is stronger per equal weight. We use 45/45 12 oz. Biaxial tape 6" wide for stingers (1 or more layers), no mat. You might even be close to our warehouse. Joel
__________________ www.boatbuildercentral.com |
| We should have asked if you are using epoxy or polyester resin, it will make a difference in what type of glass and how you use it. |
| JR Shine, are you sebastianshine on the "other" forum? I have been looking for you due to this project. Where is the shop at? I am an hour out of Sebastian. I am going to try to pick up the stuff at Fibre Unliminted in South Orlando on friday. I need to tape in three stringers and lay up the floor which is going to be about 50 inches wide by about 20 feet. Then i will need to create the fish boxes. I will need to do this as cheaply as possible. Any sugestions? |
| dont forget your Snook Stamp ![]()
__________________ Can anyone spare any gas today for a hamburger on Friday ??? |
| Which type of wood????? | william23 | Materials | 1 | 01-16-2006 04:45 PM |
| What type of rig is this? | Mark 42 | Sailboats | 5 | 03-08-2005 04:11 PM |
| A new type of core? | Fred Boyle | Materials | 7 | 01-06-2005 10:25 AM |
| To do or not to do... All glass stringers | JamesR | Materials | 2 | 10-28-2004 09:37 AM |
| Type of hull ? | David Cowen | Fiberglass and Composite Boat Building | 3 | 10-24-2004 06:09 PM |
