| Removinge decals from gelcoat Any suggestions on how to remove large decals from the side of my boat without marking the gelcoat. Kevin |
| try using a hair dryer. this might leave some glue but this can be wiped with acetone or thinners. |
| I used one of those rubber wheels that gones on your electric drill. Available from most automotive supply stores. Worked really well, removing the pin strip and the glue. All it needed was a rub down with thinner before applying new stripes. Rick |
| you can easily remove them with a little heat (hair dryer, heat gun on low) the acetone to remove the glue and finally buff it out with some polish |
| compound can also take out the glue but don't do that unless you're ready to wax the boat..
__________________ No GPS, no compass, no charts, no visibilty past 50 feet, radio recieves but doesn't transmit, cruising speed is 4 knots... yeah, sure skipper, a 3 mile run through rocks and shipping lanes shouldn't be a problem. |
| Decals and colours for Rhino | Matthew | Software | 5 | 02-21-2009 11:09 PM |
| StarCarft Decals | Gill747 | Open Discussion: All Things Boats & Boating | 0 | 12-24-2005 10:23 AM |
| Spraying gelcoat over gelcoat | alexhiguera | Fiberglass and Composite Boat Building | 9 | 08-26-2005 11:09 PM |
| Boat name and boat graphics decals | tnkingsley | Open Discussion: All Things Boats & Boating | 4 | 08-20-2005 03:47 AM |
| Original Equipment Hull Decals | bayhawk | Marketplace | 1 | 08-02-2004 01:05 AM |
