| Removing old deck gel coat-what to put back What kind of Resin to use? I have an old Sea OX 23, the gel coat on the deck is chipping loose and I have ground it all off down to the base coat with the glass cloth in it. The deck gets some flex when at sea. I plan to wash it down with acetone after getting all the loose old gel coat off. What should I use to replace the old gel coat. A manufactured gel coat or a resin with white color added. What kind of Resin poly? I plan to put it on with a paint brush. Thanks for any tips oldsaltmv |
| I would paint the deck with polyurethane paint. No gelcoat at all.
| Take care of the flex if it was enuf to cause cracked gelcoat. Gelcoat is my preference to put back on there. Clean it very well, mask very well, If you want a little nonskid, mask neatly where you WILL walk and apply gelcoat with surface agent by brush and roller, remove tape, retape a neat perimeter and wipe where the gelcoat will go with acetone rag turned often, apply gelcoat with surface agent and nonskid additive from your chandlery, remove tape while still wet. If you want a lot of nonskid, tape where you WON'T walk very neatly around the perimeter, apply gelcoat with no surface agent by roller, remove tape, "feed the chickens" with silica sand (medium sandblasing media) as evenly as possible ( I get up on a gunnel and sprinkle sand like I am rolling dice - just shake it out evenly), come back the next day and blow off or gently sweep, gelcoat with surface agent everything. You can match the color pretty close by experiment (a little gelcoat dye goes a long way) or a color match fro the gelcoat manufacturer. Rustolem 9000 epoxy (warehouse floor paint) is another option. |
__________________ "All one has to do is follow the plans and build in no permanent leaks." -Charles Minor Blackford, on the simplicity of building flat bottomed boats |
| I don't know Troy, but it is the toughest, most chemical resistant stuff I have seen for engine rooms. I hate to lead you astray about your application. |
| ..using epoxy resin, apply a layer of cloth, fill in later with epoxy and glass baloons, sand smooth, then mask up and non skid the areas as required. Use two pack polyurethane (linear) for the paint and the non skid.
| Teak deck install... West System on gel coat? | termiteslayer | Boatbuilding | 1 | 03-22-2008 06:17 PM |
| US Navy: There are several of us trying to put the crazies back in the box | kach22i | Open Discussion: All Things Boats & Boating | 78 | 06-07-2007 03:43 PM |
| Removing gel coat and spraying Awl Grip | wet-foot | Boatbuilding | 13 | 10-13-2006 12:25 PM |
| Demo work nearly finished time to put it back | robbieinga | Fiberglass and Composite Boat Building | 0 | 09-04-2006 08:31 PM |
| gel coat instead of toolin gel ? | meredog | Fiberglass and Composite Boat Building | 5 | 08-10-2006 08:53 PM |
