Old 04-30-2006, 04:24 PM
Steve71 Steve71 is offline
Redoing my floor
Hello,
I am in the process of redoing the deck on my 24' center console. I was told that if I use treated wood that the resin would not bond? Is this true? Or should I just use good "ol" plywood? I thought since I have the floor cut out that I should go ahead an replace the aluminum tank with a poly tank. I also thought that I will make a floor access should there be a need to get to the tank for the next owner of this boat.
Thanks, Steve
Old 04-30-2006, 09:25 PM
harveydoryguy harveydoryguy is offline
Rep: 10 Posts: 11
well i just replaced a section of floor on the harvey with 3/4 " balsa
its not that expensive 370 bucks for 128 sq feet ...and its cut into 2 inch blocks and has a cloth backer to keep it togeather ....molds to the bottom contors so nice ...really good stuff and light too..
i went 8 layers of may on top and 6 layers on the bottom to reinforce the existing bottom..
plus i think balsa is was alive and i like that in my boat..
Old 04-30-2006, 10:44 PM
jimslade jimslade is offline
Rep: 14 Posts: 304
Resin will bond to treated wood as long as it is well dried out. I have use it and it sticks as well as regular wood. There is a site which did testing and they got the same results. sorry I don't know it off by hand. I could find it if you want.
Redoing the bottom of a boat help simba71 Boatbuilding 5 04-29-2006 11:32 AM
floor material crum731 Fiberglass and Composite Boat Building 4 08-19-2004 04:06 PM
floor gone- now what? Guest Boatbuilding 0 06-23-2003 05:37 PM
What to use for floor? Materials 4 08-06-2002 12:23 PM
redoing floor in bow rider ventnorbuilder Boatbuilding 4 07-23-2002 09:38 AM
