Old 03-28-2006, 10:21 PM
man5 man5 is offline
Rep: 11 Posts: 37
recomended Epoxy???
Hello, I have been researching epoxies on the web and getting lost. I need it for the woven roving (roving woven ) to be used to seal and hold the new stringers and deck. Nothing fancy here probably going to put rhino lining on top of the glass on the deck cause she's going to be a fishing boat. Thanks
Old 03-30-2006, 07:37 AM
jimslade jimslade is offline
Rep: 14 Posts: 304
Why epoxy?
Old 03-30-2006, 04:09 PM
JEM JEM is offline
Rep: 38 Posts: 291
www.raka.com
Best value I've found.
Matt - JEM Watercraft
Old 03-30-2006, 08:56 PM
Rep: 11 Posts: 37
What do you recommend?
Old 03-30-2006, 09:43 PM
Rep: 14 Posts: 304
Ortho polyester resin. If it is good enough to built your boat out of it,should be good enough to repair your boat with. Its also easier to work with.
Old 03-30-2006, 09:57 PM
Rep: 11 Posts: 37
Tried to find general info about ortho and where to get it on the web. Any leads would be appreciated.
Old 03-31-2006, 01:08 PM
JEM JEM is offline
Rep: 38 Posts: 291
Easier to work with? I disagree with that.
Old 03-31-2006, 06:20 PM
Rep: 11 Posts: 37
Hello JEM, what would you recommend?
Old 03-31-2006, 06:24 PM
JEM JEM is offline
Rep: 38 Posts: 291
Give Larry at www.raka.com a call. He has years upon years of experience with your sort projects.
Old 03-31-2006, 07:29 PM
Rep: 11 Posts: 37
Thanks. Just one more Question, What kind of resin is that usc stuff that the auto parts stores sell?polyester?Anyone ever worked with Progressive Epoxies basic?http://www.epoxyproducts.com/
Old 04-09-2006, 10:28 AM
adamfocht adamfocht is offline
Rep: 10 Posts: 36
I would be comfortable using a polyester (or GP, DCPD) resin fixing the stringers in a boat that was built using the same basic kind of resin. Epoxy is great stuff but its expensive and if you use the polyester right: prep the surface, know your working times, and have the skills to do it, then you won't gain anything by using epoxy over polyester.
If the stringers were wrapped with epoxy, then you need to stay with epoxy tho.
either way is fine, just depends on how much $ you want to spend. Polyester is 1/2 (or less) the cost of epoxy.
Old 04-10-2006, 12:19 AM
frosh's Avatar
frosh frosh is offline
Rep: 44 Posts: 621
Have you heard the cliche " you get what you pay for". So it is with epoxy vs. polyester. Polyester is far more widely used because it is cheap and fibreglass boats use huge quantities of it in their construction. Epoxy is more water resistant, ultimately stronger, less brittle, has greater adhesive properties just for starters. Polyester would work but the repair will ultimately last longer using epoxy. Check with your suppliers which epoxies are suited to marine use as some are not.
Old 04-10-2006, 05:24 PM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
LOL The roving are the strands. Once they have been woven and made into cloth, it is called woven roving. If you use polyester on your project, you will have to use mat (chopped strand mat) as your first layer of fiberglass and in between layers of woven roving. I'm not sure about mat and epoxy, I've never used epoxy. Hopefully Rhino Lining comes in other colors, as black would make a hot deck. Sam
Old 04-18-2006, 09:00 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
Black decks make you learn to dance fast...
When using woven roving with polyester, you need to start with chopped strand mat, and alternate between WR and CSM. Otherwise you get resin rich areas between the WR layers which impair the interlaminair bonding strength. (due to shrinkage and brittleness of polyester)
With epoxy, you can use WR throughout, without impairing interlaminair strength.
You could also use a multiaxial in +/- 45 direction, but you need a source for that. (www.vectorply.com)
About polyester vs epoxy: there are several threads about that. I will not dive into that.
Woven roving:
CSM (the middle one on the picture)
Old 04-18-2006, 11:29 PM
Rep: 14 Posts: 304
Mat and epoxy don't mix well. The silane coating on mat needs to be disolved by the styrene in polyester resin. It will set up and cure but I have seen delamination problems. I only use epoxy for small repairs and for sealing primers. Waste of money.
When to Epoxy JosephKeel Wooden Boat Building and Restoration 8 03-04-2007 12:30 AM
Need Epoxy Help Valkyrie Materials 2 11-27-2005 01:56 PM
Vinylester over epoxy... NO !!! Capt. Chris Materials 3 09-25-2005 01:12 AM
Epoxy......how much i need? {NW}BKUSA Wooden Boat Building and Restoration 7 01-21-2005 06:14 AM
how much epoxy Boatbuilding 2 07-01-2002 06:39 PM
