| Thanks for the correction on the Trabant info. |
| Lots of different materials have been used as woven fabric in composite construction. http://www.joeharmondesign.com/
__________________ West Satsop Boatworks |
| What about using the stuff you use to waterproof your roof with we call it flash harry |
| Jeff, considering the effort that went into Splinter design and the projected result, it's a bit heavy for what it is. I could have made that car, exactly the same shape and dimensions with knitted 'glass fabrics for about a 1/3 reduction in weight and if employing some high tech fabrics, likely half it's weight. Don't get me wrong, it's clever engineering, but again heavy for what it is, which is the whole point behind composite structures, to improve the strength to weight ratio. Colfar2, I'm not sure what your roof waterproofing is, but typically it's asphalt based tar, reinforced with, wait for it, . . . 'glass fibers. |
| I am attaching the material properties of natural fibers compared against glass fiber. Notice that most of the fibers have elongation characteristic that is closer to polyester resin, that is 1.5 to 2.5%. Non postcured VE and regular epoxy has about 3% elongation and Postcured VE and EP about 3 to 5%. That means Poly is more suited to natural fibers and as PAR said, reserve the more expensive resin to exotic fibers. Problem is, these natural fibers are not yet commercially available. Years ago, I designed a boat using natural fibers. The numbers looks promising because it is lighter with the fibers at almost half the weight of glass. Jute sack is no problem as it is readily available but the high strength pineapple type fiber, the strongest, was so expensive as it is being used as clothing. Hemp cloth was available but was so coarsely woven that it would eat too much resin. It is not on the mainstream yet. Maybe in the near future. Lastly, here is a picture of a boat made of flax. |
| Dumb question for curiosity... | Xpinero | Powerboats | 15 | 03-06-2011 12:48 PM |
| The only dumb question... | F.H.B. | Multihulls | 5 | 12-23-2009 12:17 PM |
| Dumb question about gauges | Risejugger | OnBoard Electronics & Controls | 1 | 04-18-2008 04:19 PM |
| Dumb question | DanBlack | Open Discussion: All Things Boats & Boating | 7 | 08-10-2007 10:12 AM |
| Maybe a dumb question? | sailortoo | Sailboats | 2 | 01-10-2006 05:45 PM |
