Old 12-11-2007, 12:33 PM
rwstoney's Avatar
rwstoney rwstoney is offline
Rep: 10 Posts: 4
Raising the transom
Two years ago I rebuilt the transom on my 23 foot center console to replicate the original design except I used Coosa 1 1/2" Bluewater 26 rather than plywood. I layed it up with epoxy and 4 layers of 1708. It is holding up great. Now that I'm a little bit smarter I want to raise the transom to 30" to eliminate the water coming in the motor well when backing down or drifting. What I'm unsure of is how to tie in the 5" higher transom to the original rebuild so it is strong enough to take the motor loading. Any help would be appreciated.
thanks
Old 12-14-2007, 03:18 PM
Rep: 1397 Posts: 7,216
Grind the surface to about 6" from the edge. Make sure is tapered to the core on the upper edge. Set the Coosa filler in a couple of layers of resin soaked fiberglass. You can put four or five screws through to hold it in place. Fiberglass over everything with four layers of 1708.
Old 12-15-2007, 10:52 PM
AroMarine AroMarine is offline
Rep: 10 Posts: 45
What type of boat is it? Are there molded in seats or storage compartments? Gonzo is correct on the taper. But the interior side of the transom is usually the most problematic repairs or rebuild.
Old 12-17-2007, 08:18 AM
rwstoney's Avatar
Rep: 10 Posts: 4
The boat is a 1973 23 ft seacraft. Attached is a link to the transom rebuild in progress from 2005. http://www.myfishingpictures.com/dat...icture_050.jpg
There are storage compartments on the side but I can work around them.
how far do the 4 layers of 1708 have to be overlapped onto the existing for strength?
Strengthening a Transom ducknuts Boat Design 7 09-14-2006 02:49 AM
raising my top and mast john a roberts Sailboats 2 07-24-2006 07:01 AM
transom shelbygone Boatbuilding 10 07-08-2006 07:10 PM
Partially raising a dinghy centerboard amolitor Sailboats 12 02-18-2005 04:37 PM
transom bammy the bass Fiberglass and Composite Boat Building 1 09-27-2004 06:03 PM
