http://boatbuildercentral.com/products.php?cat=41 I also buy from some specialty formulators for infusion stuff etc.
__________________ Yours Aye! Rick M/V She:Kon Blog ~^~^~^^~^~^~^~^~^~^~^~~^~^~~^~^~^^~~^~^ "It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up! |
| Mitch, simply put, polyester just doesn't do anything nearly as well as epoxy does. This is a material that's best suited in molds, under controlled conditions, applied against itself and nothing else. Attempting to save money by using a resin other then epoxy is false economy. The polyesters don't stick to wood very well, they absorb moisture, they're not very strong, have to be applied thickly to offer strength, which makes it heavy, etc., etc., etc. If you're building a 'glass boat in a mold or with a one off method, then one of the polyesters is an option. If on the other hand, you're looking to use polyester in place of epoxy on a wooden build, you'll be sadly disappointed. |
| West System epoxy over D.E.R 331 epoxy | bobbychuong | Materials | 8 | 10-18-2008 03:13 AM |
| Pine Ply + Epoxy 4 questions for the price of one | |Eric| | Materials | 16 | 03-17-2008 04:52 AM |
| epoxy primer sprayed on green epoxy laminate? | bntii | Boatbuilding | 12 | 10-16-2006 06:41 AM |
| Epoxy resin and cloth selection questions | sbklf | Materials | 1 | 05-03-2006 12:15 AM |
| CPES, Epoxy and Fiberglass Questions | Guest | Boatbuilding | 4 | 09-04-2003 08:06 AM |
