  #31
Old 07-09-2010, 12:01 AM
rxcomposite's Avatar
rxcomposite rxcomposite is online now
Rep: 746 Posts: 785
Originally Posted by AndrewK View Post
rxcomposite, I disagree with what you are saying about infusion, there is a thread on infusion that we can take this up in if you like.
Is the thread in this forum or another forum?
  #32
Old 07-09-2010, 07:12 PM
AndrewK AndrewK is offline
Rep: 338 Posts: 377
It is Infusion Q&A, one thread that you just keep adding to.
Infusion Q&A
  #33
Old 07-09-2010, 10:16 PM
jonr jonr is offline
Rep: 34 Posts: 246
> When mixing resin, bubbles is inevitable
This is the part I don't understand - if one mixes two degassed liquids in a vacuum, where would these bubbles come from?
  #34
Old 07-10-2010, 12:39 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
chemical reaction !!
  #35
Old 07-10-2010, 01:53 AM
Rep: 746 Posts: 785
from the act of mixing the mekp to the resin. I find electric motor mixer has less bubbles than manual mixing.
2 to 5 mins if the vac is high, or if low as andrew says minimum 10 mins.
  #36
Old 07-10-2010, 02:00 AM
Rep: 746 Posts: 785
Infusion Q&A
Thanks Andrew,
I will read it first then go back to you. You failed to mention where you disagree with me. I may have been too general. Funny but as I read your post, I find that yours is very very close to what I am doing and I have not seen things contrary.
I always try to learn new tricks. I hope I find the forum informative.
Regards,
Rene
Vacuum infusion question please Fanie Boatbuilding 10 11-16-2008 10:39 AM
Recommended vacuum pumps for vacuum bagging? James Mills Materials 1 12-17-2006 03:11 AM
Vacuum infusion Question Mihajlo Fiberglass and Composite Boat Building 6 10-12-2006 04:11 AM
vacuum bagging or vacuum infusion Eisa Hasan Fiberglass and Composite Boat Building 10 03-29-2005 03:25 PM
Vacuum Bagging Question turnershells Boatbuilding 0 01-20-2003 12:33 PM
