Old 10-11-2010, 08:40 PM
hyboats's Avatar
hyboats hyboats is offline
Rep: 10 Posts: 42
pump for 23ft boat ?
How many pumps and the capacity should I install for 23ft Center console fishing boat ?
I am thinking fix two automatic pumps, 1800GPH /per . Is that right ?
Bruce
Old 10-11-2010, 09:38 PM
Rep: 3125 Posts: 9,399
I'll assume you mean bilge pumps. Install the biggest darn pumps you can find and hope you don't ever need them, because they will not be enough. Mount one 2" higher then the other. A leak the size of a weak garden hose will overwhelm a 2000 GPH pump. A thunderstorm can drop enough rain to overwhelm a 2000 GPH pump. So, pick your equipment wisely.
Old 10-16-2010, 09:28 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Totally agree !! The bigger the better and dont forget it needs power to make it work !!!
Not only float switchs but manual switchs as well !!Never rely solely on a automatic switch .
I have the over board exits in a place where they are easy seen and if a pump goes at anytime i find out why and what caused it straight away !!.
Making beautiful boats is a passion never a chore !
Should instal a toilet for a 7m(23ft) center console fishing boat ? hyboats Fiberglass and Composite Boat Building 8 09-22-2010 01:08 AM
Merc 135 prop sizing for 23ft. IVB Fiber Artz Props 14 06-18-2010 06:15 PM
23ft center console chowdan Boat Design 8 02-28-2009 06:04 AM
Sea Star 1975 23ft Flats Boat Boathustler Open Discussion: All Things Boats & Boating 0 08-29-2006 12:46 AM
Heat Pump => Vacuum Pump Inquisitor Boatbuilding 7 11-12-2005 09:29 PM
