Old 08-08-2009, 11:18 PM
Carbonman Carbonman is offline
Rep: 10 Posts: 8
Print through
Today after making a few carbon fiber parts via vacuum infusion I noticed that under 100F they start to print through the surface. I know its due to the heat and no matter what carbon fiber will always have print through weather its minimal or allot but what are ways to reduce this?
I vacuum infuse parts with epoxy resin (a little thicker then I should be useing) and then I apply 2 layers of urathane automotive clear coat. Wet sand with 800, 2000, buff and polish. SO the top layer is very thin.
Can I just spray on a few layers of epoxy, wet sand, then put the automotive clear over that and shoudl that reduce the print through majorly?
I did notice when I used to do vacuum bagging where I would just put on a clear gel coat I would get less print through. But I dont want do put gel coats since its vacuum bagging. So is spraying on laquer thinned epoxy resin my best bet?
Do you recognize this foot print? (Wood bug) CanuckGuy Materials 3 05-18-2009 10:23 PM
Ceramic print barriers Landlubber Materials 0 08-20-2007 12:16 AM
painting hull - covering Print Through superfly Fiberglass and Composite Boat Building 4 06-16-2006 07:29 AM
Help with Print-through Problem In The Hull genuineyachts Fiberglass and Composite Boat Building 18 09-23-2004 12:08 PM
