| Primer Suggestions Hey guys...I am getting ready to shoot my project boat. I am top-coating the hull with white IMRON. My question is what primers would anyony suggest? I was thinking about a high build then a final primer then the Imron topcoat. Considering duratec primers under the Imron. I would appreciate any feedback. Thanks! |
| I would use Duretec sanding primer,itseems to work very well and is easy to sand,then I would use a Dupont non-sanding sealer under the Imron which is a good choice by the way.Wear a good respirator,I painted cars for 20 years before I started in fiberglass and Imron is the only paint that ever hurt me and it only took 2 breaths to put me in the bed for 2 days. Good luck Jeff Therrell |
| I've used polyprimer which I was able to sand nicely to a dull lustre before gelcoating. How does duretec compare to polyprimer? DOes it bring better results? |
| Use a good epoxy primer or your lookin for trouble later on. Epoxy is will stop osmosis. poly base primers unless vinylester will not. |
| Weldable primer? | ted655 | Metal Boat Building | 16 | 03-07-2011 08:14 PM |
| epoxy primer | portpennscrabs | Boatbuilding | 4 | 12-30-2008 06:39 PM |
| do i need to primer before paint? | revshot | Fiberglass and Composite Boat Building | 5 | 03-19-2006 01:29 PM |
| Old Primer - Blast or Revive? | m-s1 | Boatbuilding | 1 | 12-12-2005 12:24 AM |
| Epoxy Primer/Interlux | alexhiguera | Materials | 0 | 02-03-2005 06:09 PM |
