| Primer or paint instead of gel coat in a mold I'm interested in any experiences people may have had in spraying primer or paint into a mold instead of gelcoat and laying up directly on the paint or primer using epoxy resin. |
| Hard experience tells me it's a precarious buisness at best. However, Ive had pretty good luck with Pro-Line cold cure. (Y3066) But make damn sure your release-agent will work with it first. |
| Oh yeah, you can always spray PVA in the mold first, it just releases a little bit too good. Yokebutt. |
| I use this method on My IOMs Doug. Works a treat. Prepare the mould with PVA release. 2 pack epoxy primer sprayed into the mould. Then layup as usual. Once the hull is released from the mould all that is needed is a light sand then topcoat. I have even tried this method with spray paint from an areosol can..need to allow a longer period of time before layup and de moulding though. Tactic |
| paint/primer I've used it on models as well(see www.microsail.com) For paint I pour in the PVA and stand the mold vertcally to drain-dry's with no surface imperfection. I've used Imron and -believe it or not Krylon-both work well. On others I've sprayed PVA and used a catalyzed primer. I was curious if anyone thought there would be unforseen problems in using this technigue on larger pannels ,say 16' by 2' ? I've never had print thru in a model but I'm wondering if the larger pannel was resin infused(layed up on a glass sheet) if I'm likely to see it. |
| I guess you need to mke some test panels then Tactic |
| Gel coat paint | Nicole Penn | Materials | 7 | 08-12-2006 02:48 AM |
| milky patches in clear gel coat | still afloat | Fiberglass and Composite Boat Building | 3 | 07-22-2005 04:29 PM |
| Gel Coat vs Fiberglass | pramdx | Fiberglass and Composite Boat Building | 6 | 07-18-2005 07:44 PM |
| how much resin? | Lew Morris | Materials | 3 | 06-22-2004 07:13 AM |
| Life span of gel coat | Materials | 0 | 12-24-2002 03:52 PM | |
