| I glassed a 16 ft cedar strip runabout, learned alot. My 2 cents. Use 2 layers of cloth and a slow cure epoxy(24 hrs). Glass in one step. Warning! make sure the wood is very dry and if you can epoxy coat the inside, this will stop the expansion of the wood when wet. |
| Using 1 layer 30oz triaxial + one layer 10oz uni extra in the slam zone.Wood is 14%, as low as I can keep it in this climate. Frames are being removed & glassed inside as well. thanks for the tips. |
| wooden mast | wanaco | Materials | 8 | 07-05-2008 11:34 AM |
| planning on cutting a wooden hull along the centerline | jedclampit | Wooden Boat Building and Restoration | 25 | 07-11-2006 09:28 PM |
| bonding to wooden hull | Lunde | Wooden Boat Building and Restoration | 4 | 09-16-2005 07:48 AM |
| Wooden or Fiberglass | berkin | Boatbuilding | 10 | 12-31-2004 02:42 AM |
| Painting a Wooden Hull | Guest | Boatbuilding | 1 | 09-23-2003 09:11 AM |
