| Can also be caused by gelcoat that is too thin , thereby resulting in undercuring and wrinkling.
__________________ Im working on my second million.........I gave up on the first! |
| Xander, you havent by any chance got your hands on one of those godamn awful silicone release waxes have you that they made a few years ago. I remember we tried them when they were around and they caused this type of problem as well.
__________________ Im working on my second million.........I gave up on the first! Last edited by Itchy&Scratchy : 01-07-2010 at 04:19 PM. Reason: left out a few words |
| ....most likely the thin gelcoat as I & S suggested....
| ....you do not get a name like that unless you have played with the product......poor bastards.
| No, I've got a good wax. It's the temperature, mix ratio and thickness of application that's causing me grief. Hopefully I can correct for all three in one more attempt or else I'm gonna try a different approach to my project. Thanks for all the advice. |
| No morries mate, just leave a beer in the fridge.
Prelease is caused by the product you are making shrinking away from the mould ! ok ? so what causeing that problem ?? Alligator problem , this can be cause by thin gel coat (SPECIALY IF YOU ARE BRUSHING )/ undercured gelcoat- (not enough catalyst) (ratio to low ) or a slow brew on the second coat of gel . General rule for gel coating is first coat at 1.5 % of catalyst /second coat at 2% catalyst and let cure at 20C over night !! ![]() |
| Pre-Preg and Balsa... | AppleNation | Fiberglass and Composite Boat Building | 10 | 01-08-2009 05:51 AM |
| Mold making pre release, Help? | jim lee | Fiberglass and Composite Boat Building | 16 | 08-15-2008 05:14 PM |
| Question re: Semi permanent mold release problem | dberr | Materials | 3 | 07-26-2007 09:16 PM |
| Release problem W/Chemlease #15 | Thin water | Fiberglass and Composite Boat Building | 5 | 09-27-2006 03:07 AM |
| Pre Release | brad123 | Fiberglass and Composite Boat Building | 1 | 04-17-2004 09:03 AM |
