Old 07-28-2011, 07:51 AM
kai987 kai987 is offline
Rep: 10 Posts: 2
Practical tests for the workshop
Hi all,
I'm looking for practical tests that you can perform in a workshop to test if a foam sandwich coupon is made properly - some kind of rough and ready quality control.
Been looking at ILSS and modified mode I fracture tests etc, but I wonder if I'm going overboard. The goal is to basically verify that contaminants haven't affected the final composite, given the many sources that they could come in... peel ply coating, breather, or even in FG sizing. Given that the major failure modes are typically delaminations, I thought some kind of shear/fracture test would be applicable...
Or is sending coupons off to the lab the only way?
Thanks
Kai
Old 07-30-2011, 04:42 AM
Rep: 10 Posts: 2
Astm D 1781
The drum test seems to be a good qualitative test.
Should say I'm not doing this in a commercial workshop... Does anyone have a diy rig setup to do a drum test, without buying an Instron?
Ta
Smallest model scale for representative tank tests ? Boo2 Sailboats 13 03-22-2010 08:55 PM
editorials boat tests lazeyjack Boat Design 0 07-09-2008 04:17 PM
Stability tests in berth pynchon Stability 2 05-18-2008 04:21 PM
Let´s be practical. Are we in the right way? Antonio Alcalá Stability 0 11-06-2007 08:43 AM
A practical procedure for flotation and stability tests Smarten Boat Design 4 06-02-2006 12:06 PM
