Old 02-21-2005, 04:33 PM
Ssor Ssor is offline
Rep: 10 Posts: 174
polyester resin shelf life
I am bewildered. I have a gallon can of Evercoat finishing resin, maybe 2-3 years old, still pours from can, no lumps in it, but catalysed @ 3% it still will not harden. Does MEKP go bad? I have had polyester resin start to harden in the can but has anyone found that it wouldn't harden? I have used this same can in the past with good results.
Old 02-21-2005, 10:52 PM
Rep: 10 Posts: 174
I believe that I have answered my own question. The MEKP that I used initially was about three years old in one of those little 40cc clear plastic tubes that had been exposed to sunlight in my garage. I mixed another batch and used some MEKP that I had in a half gallon jug in a cardboard box in my basement. The batch mixed with the MEKP from the basement gelled and hardened in the proper length of time. So I think that the answer to my question is, Yes, MEKP can deteriorate with time. The MEKP from the tube didn't smell right, not that sharp acrid odor that is characteristic. I guess the conclusion is; if you have any doubt about your catalyst, buy fresh.
Old 02-24-2005, 05:26 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
Indeed, Mekp goes bad under influence of sunlight. Try and store it in a closed container, in the dark.
If the polyester resin is still what it should look like, it usually is still OK, but do some testing beforehand. (geltime could have drifted somewhat).
Old 02-24-2005, 07:58 AM
Rep: 10 Posts: 174
Herman,
Thanks for the confirmation. I always test, if I haven't used the resin recently.
Ross in BelAir
Absorbtion of Polyester resin by carbon uni Doc Martin Fiberglass and Composite Boat Building 11 04-18-2005 02:29 PM
Polyester Resin Floor Coating FishTales Materials 4 09-26-2004 10:45 PM
Shelf life of Cobalt-12% ??? Glenn Shotwell Materials 2 08-21-2004 11:51 PM
epoxy or polyester resin gbaaron Powerboats 2 06-20-2004 09:52 PM
Is Vacuum bagging suited to GRP/ polyester resin layups ? VIKING Fiberglass and Composite Boat Building 6 05-07-2004 11:00 AM
