Old 01-22-2008, 02:38 AM
Whale1 Whale1 is offline
Rep: 10 Posts: 3
Polyester resin and plywood
Just a question what types of ply can you use poly on?
Marine grade Ply , Construction ply untreated ?
I once glassed some bracing for a mold with treated ply and it lifted off by itself.
Please help
Old 01-22-2008, 09:49 AM
alan white's Avatar
Rep: 1168 Posts: 3,270
You can use polyester resin on either marine or untreated and it will adhere the same. The bond will last a while, but it will let go eventually, especially if water gets behind it.
The difference between marine and treated plywoods has to do with several major factors. The marine ply has fewer voids in the inner plies, it is made of a species of wood that can survive better in water, and it uses waterproof glue. That isn't to say non-marine plywood doesn't often share some of these attributes. It is just that the non-marine ply wasn't manufactured with all of those attributes in mind. If it can be used for boat construction, it wasn't because the manufacturer intended it to be.
Alan
Old 01-22-2008, 03:18 PM
Trevlyns Trevlyns is offline
Senior Citizen/Member
Rep: 461 Posts: 689
Hi Whale1 and welcome to the forum!
There has been so much discussed on this topic, I’d recommend you start reading up on some “similar threads”. Just scroll down to the bottom of this page. That will get you started!
Best
Trev F – Amateur designer and part-time layabout.
Old 01-22-2008, 03:48 PM
Rep: 10 Posts: 3
thanks guys for the help.
So definatly dont use treated ply??
Old 01-22-2008, 08:30 PM
Rep: 2891 Posts: 8,798
Treated plywood needs to be dry, which as found in most lumber stores, is still quite wet from the treatment process. The moisture content should be below 15%.
Polyester isn't the best choice for adhering a sheathing (in fact about the worst of the modern resins) vinylester is the best of the polys, with epoxy far better then any. It's a moisture vapor thing and good epoxy will keep over 99% of it out of the wood, where unrefined polyester (the cheap stuff) is lucky to keep out 90%. The moisture eventually permits the wood to swell and contract with content changes (a natural thing with wood). This movement eventually "sheers" the sheathing from the wood.
If you're going to use pressure treated plywood, check its moisture content before applying resin. This is true of any wood or wood product (like plywood).
Protecting Plywood with Polyester Resin asianbandit Materials 16 05-04-2009 03:50 PM
epoxy vs polyester resin mkpardy Boatbuilding 11 01-23-2007 11:23 AM
Polyester resin problems. zoso Wooden Boat Building and Restoration 9 10-18-2006 09:39 PM
Polyester resin roko Fiberglass and Composite Boat Building 10 11-28-2005 08:39 AM
epoxy or polyester resin gbaaron Powerboats 2 06-20-2004 09:52 PM
