Old 11-22-2005, 09:00 AM
roko roko is offline
Rep: 10 Posts: 16
Polyester resin
Hei people
I need some help with polyester resin core time.
i have polyester resin that is allready mix with catalizator only need to put in some hardner.
Now the question is how much hardner i need to put in 1 liter of poliester resin and still to have great time to work with resin.
Eny CORE TIME DIAGRAMS???????
Thank you for future answer!!!!
Old 11-22-2005, 10:57 AM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
there may be diagrams but experience is the best teacher here, forexample cooler temperatures, but not to low, can double your time
Old 11-22-2005, 11:03 AM
Rep: 10 Posts: 16
yipster thank you ,
i need info how long that time can be and mix ratio!!
What your exspirance can tell me?
Thanks once again
Old 11-22-2005, 11:30 AM
yipster's Avatar
i have some good books on the subject and talk with my supplyer.
if you do a search youll find planty information. what i'm saying is get on your "trow away gloves", put some floor cover down and DO it.
if your not sure mix a little first and see how it reacts.
say half an hour is normal but time is critical and if resin gets hard before your finished dont try to use it.
really, just get started and soon enouch you master hand layup.
Old 11-24-2005, 02:29 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
0.75% is usually considered the lowest safe amount as long as it's not too cold.
Yoke.
Old 11-24-2005, 07:02 AM
Rep: 10 Posts: 16
thanks yokebutt
Old 11-24-2005, 09:57 AM
Ssor Ssor is offline
Rep: 10 Posts: 174
I always weigh my resin and measure the catalyst with a 12 cc hypodermic syringe. From .75 % up to 2 % is the range that I use.
Trying to use polyester resin in direct sunlight will shorten cure time dramatically. But you must play with it a little to learn how it and the cloth behave. Get some pieces of scrap plywood and work up different shapes
, bore a big hole in it and make a patch, try glassing a 1x2x3 block of wood to the plywood. 1 1/2 ounce chopped strand mat will conform to a ball if you are patient. Work with a throw away bristle brush, disposable gloves and buy a can of acetone for clean-up. 2 ounces of resin is enougth to saturate 1 ounce of glass cloth with plenty to spare.
Old 11-25-2005, 01:18 AM
Rep: 1397 Posts: 7,216
The amount of catalyst is also proportional to the thickness of the laminate. Too much can make it go on fire.
Old 11-25-2005, 09:24 AM
Sander Rave's Avatar
Sander Rave Sander Rave is offline
Rep: 59 Posts: 201
Just do it some testing and try to detect when the matter changes. That's the moment to stop. The ratio I use (as a hobbiist) is 1-4% and temperatures above 10 deg.C.
Sander Rave
SkottKarra industrieel ontwerpers
skottkarra.com
Old 11-25-2005, 12:13 PM
Rep: 10 Posts: 16
thanks guys any more comment is more than welcome
Old 11-28-2005, 08:39 AM
jimslade jimslade is offline
Rep: 14 Posts: 304
1 to 2,5 percent is the norm. trying to laminate in cold or very hot situations is problematic. always try a sample in the temps you are working with.
water based marine grade polyester resin Buckle Fiberglass and Composite Boat Building 15 01-25-2011 06:03 AM
Absorbtion of Polyester resin by carbon uni Doc Martin Fiberglass and Composite Boat Building 11 04-18-2005 02:29 PM
polyester resin shelf life Ssor Fiberglass and Composite Boat Building 3 02-24-2005 07:58 AM
Polyester Resin Floor Coating FishTales Materials 4 09-26-2004 10:45 PM
Is Vacuum bagging suited to GRP/ polyester resin layups ? VIKING Fiberglass and Composite Boat Building 6 05-07-2004 11:00 AM
