Old 08-24-2004, 02:57 AM
LKJR LKJR is offline
Rep: 10 Posts: 17
poly vs epoxy manufactured to repair
so are most boats manufactured using the poly resin or epoxy? if a switch roughly when was it?
and if epoxy and poly resins don't stick together well why are the majority of fiberglass repair kits poly and not epoxy?
wouldn't this cause problems?
Old 08-24-2004, 09:35 AM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
Polyester is cheaper. For production boat building, epoxy is too expensive.
Old 08-24-2004, 02:03 PM
Rep: 10 Posts: 17
so why use epoxy on repairs? such as stringers and such if it dosen't stick to the polyester as well?
Old 08-24-2004, 02:14 PM
SHINE
Rep: 50 Posts: 282
A repair done with polyester on a polyester hull will not be bonded as well as an epoxy repair done on a polyester hull.
There is a LOT of material out on the web about poly vs. epoxy. Sometimes you'll find conflicting posts, but on this subject, its pretty clear.
Can you make repairs with polyester resin? Yes. Especially if your dealing with small patches or cracks. But if you are putting in new stringers or a transom - epoxy is the way to go.
It seems like your waiting for someone to come along and tell you its OK to use polyester for a stringer replacement, so I will say it - go for it! But know the compromise you are making.
Old 08-24-2004, 03:56 PM
Rep: 10 Posts: 17
no I"m actually not looking for someone to tell me that, I'm just trying to soak up as much knowledge as possible here. just trying to get a better understanding of the differences and what's compatable with what.
thanks for the reply
Are Your Glue Joints Repairable? Bob Smalser Wooden Boat Building and Restoration 16 04-18-2007 07:23 PM
What type of resin to use? epoxy or poly. for this hole in Bow? J-Bird Fiberglass and Composite Boat Building 4 12-25-2005 12:21 PM
Epoxy crystallization jfblouin Materials 4 09-15-2005 12:19 PM
Easier way for balsa core deck replacement? pago cruiser Boatbuilding 4 06-01-2005 07:20 PM
Gelcoat over Epoxy wet-foot Boat Design 9 08-16-2004 07:58 PM
