Old 06-19-2005, 12:28 PM
EricT EricT is offline
plywood cored GRP laminate
I am about to build a modular Polyester glass hulled catamaran houseboat, and because the sides and bottom of each module (6ft long x 3 x 3) are flat I am considering using half inch ply as a core. Some of the modules will be used as tanks for fresh, black and graywater so will be exposed to moisture from inside and out. It is my intention to coat the inside and outside of the hulls (below the waterline) with epoxy.
Will this be sufficient to prevent moisture getting to the ply and causing rot or delamination, or both?
Cost is a consideration here but so is longevity.
The boat will be used in saltwater.
Any ideas?
Old 06-19-2005, 06:41 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Normally, you don't want to combine polyester and epoxy. With plywood you should use only epoxy and no polyester. You can add a thin layer of glass as a protection to avoid scratches, but you probably don't need the glass for strengt (stiffness).
While epoxy costs many times more than polyester, the total cost may be lower because you use more plywood and less glass (and thus less resin).
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Use of plywood for internal structures RubinB Fiberglass and Composite Boat Building 1 08-19-2005 11:59 AM
Boatbuilding plywood rdbct Wooden Boat Building and Restoration 3 02-05-2005 06:12 PM
plywood rotting in transom - grp boat brian c Fiberglass and Composite Boat Building 2 10-07-2004 06:54 PM
mahogany marine plywood structure? blackspot Materials 13 10-06-2004 09:39 AM
Plywood specs from the user point of view amitk Materials 0 10-04-2004 12:13 PM
