Old 01-14-2006, 06:40 AM
buckknekkid's Avatar
buckknekkid buckknekkid is offline
Rep: 37 Posts: 345
Originally Posted by zerogara
The easiest way to show your customer how proficient you are in your trade (surveyor) is to criticize all problems of a boat as the manufacturers' faults and lack of understanding. That makes you an engineer.
Many of those "scientists" that run around boatyards with pens and rulers in their shirt pocket don't know from which side the fish farts!
the back usually
Can anyone spare any gas today for a hamburger on Friday ???
Old 01-14-2006, 10:24 PM
MBW MBW is offline
Rep: 10 Posts: 2
There are only 1 or 2 cores that should be used in hull bottom(my opinion) Core-Cell and Airex. Look at the following websites. http://www.hightechcomposite.com/the...ed_product.htm These guys have been using core-cell in the bottom of offshore race boats for ten years and they know what they are doing. If you do not have the time, skill, or resources to "properly" vacuum bag the core to the laminate, you should not use cores in your boat! Heres a boat using Airex in the hull bottom. http://www.dragonpowerboats.com/
This boat is built by Hightechcomposites at the previous website. Again, these boats are vacuum bagged every step of the way. There built using epoxy with a 14 hour cure window. I know this because I used to work there. Lastly, here is an article from yachtsurvey boasting about the properties of Core Cell. Like buckknekkid said, it comes down to the skill of the crew.
Plug and mold construction sandman1984 Boatbuilding 3 12-23-2005 08:08 PM
mold insert to deal with negative return corners?? Pavook Fiberglass and Composite Boat Building 4 11-28-2005 01:10 PM
Need a Mold Made Bob Hostetter Marketplace 6 07-14-2005 11:00 AM
Help Wanted Design, Plug, Mold and Builder Cpt Albert Fiberglass and Composite Boat Building 7 07-01-2004 06:45 PM
Help Wanted Design, Plug, Mold and Builder Cpt Albert Boat Design 0 06-28-2004 09:55 AM
