Old 07-11-2004, 09:59 AM
gasdok007 gasdok007 is offline
Rep: 10 Posts: 24
plug fairing
I was thinking about making a plug by covering plywood bulkhead/rib framing with thin plywood but the filling/fairing issue will be overwhelming. Has anyone tried to cover the surface of a plug with a somewhat flexible smoth surfaced material like formica or sheet vynyl flooring,or is there a specific product available for this purpose.?
Old 07-14-2004, 02:16 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
Mica will leave a terrable profile on the Mold,It is hard to escape a Glassed Plug and Fariing compound/spray surfacer and the Hand Sanding..
The CNC'ed stuff still requires the spray and Lot's of hand sanding.. But again depends on what you are looking for.
Slippery when wet.
www.cheetahcat.com
Old 07-14-2004, 04:35 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
There is always melamine board or......That crap board....made from sawdust and resin...whatever it's called. If you think you can get away with it-use it. Atlantis Yachts used it to make moulds for their cat hulls.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 07-15-2004, 05:59 AM
Rep: 10 Posts: 24
checked out your cheetahcat website.Very cool indeed.I'm not sure what you mean when you say mica will leave a terrible profile.It seems to be bendable to the type of radis I need and has a slick surface.I know I cant avoid all hand sanding,butI can acheive fairly large smooth surfaced panels,I can avoid alot of it.
Old 07-15-2004, 01:28 PM
Rep: 84 Posts: 661
Mica is workable I am not disputing that point, what I am trying to say is the material does not give a surface nowhere close to a professionally sanded one... A couple reasons the material itself is not consistent and even with the best spray up on the adhesive/bond line there is still the oatmeal look at low-level. Plus during lay-up there are prerelease issues if one is not careful.
I am just very critical of Plug and Mold work; it is imposable to beat a guide coat job with a Trued Metal file and PSA Abrasive...
Each to his own, quick and dirty Mica or some other refinished material hands down will get you there.
Slippery when wet.
www.cheetahcat.com
Old 07-15-2004, 04:25 PM
Rep: 10 Posts: 24
I should mention that the moulded boat will not have gelcoat but will be an epoxy lay up(I can't Stand styrene),and will probably be primed and painted with an epoxy primer and urethane topcoat. Joint lines will have to be filled and faired. As for oatmeal- there are some very slick finished micas out there, and I wonder if I need a more mat finish to get tooth for the Primer?
Old 07-15-2004, 07:07 PM
Rep: 84 Posts: 661
Sorry thought you were using a different system..I meant Like a panel Job pulling finished sections..Anyway my Idea of finishing is a little different than most.. Like the nicest faired stuff at the Beach show..
Slippery when wet.
www.cheetahcat.com
Old 07-16-2004, 09:35 AM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
Hey Gasdok,
What are you building? We are right down the road (Vero).
Joel
Boatbuildercentral.com
Spray on fairing material? Capt. Chris Fiberglass and Composite Boat Building 28 09-28-2010 01:48 AM
Questions on plug building... Pavook Fiberglass and Composite Boat Building 8 09-06-2005 02:42 AM
Plug Construction and post cure. ClarkT Fiberglass and Composite Boat Building 3 08-19-2005 01:37 AM
One-off plug building question nemo Boatbuilding 8 07-24-2005 05:04 PM
Hull fairing software (big ship) MaciekP Software 12 03-31-2004 02:24 AM
