Old 09-17-2011, 06:08 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
The first thing to try is to do a sample layup without the peelply on one side, and with the peelply on the other side, and see if you get the bumps on both sides.
Micheals comment about the warts going in lines is very important - I thought it was from plank lines, but if not, then the weave of the fabric or the peelply is the key
PS - DO NOT apply epoxy to the top of the cloth.
The only thought that I can come up with is that the patches of 'above ground' epoxy, puckered the peelply, pulling along the threads as they cured. I know that when 'goo' dries, its distorts any fabric it is sitting on.
Old 09-18-2011, 02:13 AM
Rep: 670 Posts: 2,457
It will be interesting to discover the cause of your problems. Im only an amateur laminator, using less than best craftsmanship, and have never had any wart type problems when using peel ply
Old 09-18-2011, 06:18 AM
querulant querulant is offline
Rep: 10 Posts: 7
I am curious as well. The "warts" as you call them are aligned with the peelply, not with the wood grain (which was diagonal mostly).
I will try and do a couple of tests:
plywood, treated with epoxy, sanded, then laminated over. This covered in:
-wet peelply (not soaking, but storage in 100% humidity)
-dry peelply
-no peelply
-other peelply if I have it available (the sample of Econoply G is used completely)
and the same for a melamine board, to exclude effects of the wood that is beneath. (although I do not expect the wood to be the problem)
I will try and make photos in the process
Old 09-18-2011, 06:38 AM
Perhaps take a sheet of peel ply, pour a bucket of water over it and watch the water run off to expose any " Beads" indicating contaminants ? But even then, contamination normally shows up as fish eyes, not warts, in the finished product.
On dockwalk there are a couple Pro laminater composite guys. Poster HERMAN is one. Perhaps pose your question directly to him..
Old 09-18-2011, 07:16 AM
Rep: 10 Posts: 7
Good idea about the "water test". Although Airtech claims their peelply is scoured, you never know...
I will try and contact HERMAN as well.
efficiency of surface drives and surface piercing propellers David Knight Powerboats 7 09-24-2009 04:10 PM
Uneven Wake Pattern 50HP Outboard wheresbob Outboards 19 07-05-2008 08:56 PM
A Strongback for uneven ground - any ideas? Trevlyns Wooden Boat Building and Restoration 6 03-24-2008 06:39 PM
Shape vs. Surface oceangboy2000 Software 1 03-02-2006 04:55 PM
3D Surface Help lazza Software 1 06-05-2005 01:46 PM
