| Part stuck in mold!! Yikes!! Tried taking the part off of my mold all day today! Put 4 coats of mold release wax and it still wouldn't budge. It is in the shape of an L rotated 90 degrees counterclockwise. I was able to separate the vertical portions of it but the borizontal areas of the part is not budging. Is there a way to get the part out without carnivorizing the mold?? Thanks in advance for any help. |
| Hi there are 2 methods we used to use to release stuck mouldings, the first one is to drive wood wedges between the released parts of the mould then poor hot water in & time will tell wether it will let go.The other is to drill small holes through the mould hopefully stoping before damaging the moulding & glass on nipples suitable for connecting an air line, then blowing compressed air between the mould & moulding. Hope this is of some help Regards Mark |
| Two further questions:first one being do you need to make another part from the mould?Seondly,is the mould in one piece? |
I initially started with a mid-sagital section of the mold very carefully trying to make sure I have a satraight line and all.. Long story short: the end result came out to be a few additional torn sections where the mold stuck to some corners where it had been filled with cabosil. Bad day today. |
| You can always use the part that you have as a plug for a new mould .... |
| in future consider the use of chemical or water base sealers and monocoats, with wax as a an intial form of protection. We have two very successful release coat systems in production. U need to taylor ur release coat system to ur process. A tried and tested system which may work for one particular gelcoat and tooling system may not work on another. For example, a slight change from a polyester gelcoat to a vinylester gelcoat will require a much more durable release agent system, as vinylesters are much more aggresive. Have u recently changed ur process?
__________________ Buckle (Composite Engineer) |
| Hi all pleased to be part of your community | Fishy Phil | Open Discussion: All Things Boats & Boating | 12 | 03-01-2006 04:52 AM |
| hello everyone, i seem to be stuck on a northwest yacht ownership binge. | rustyone | Sailboats | 0 | 12-11-2005 12:57 PM |
| Float Stuck In Gas Gauge | MISSY2U | Powerboats | 3 | 03-12-2005 01:22 AM |
| Yikes!! | Willallison | Open Discussion: All Things Boats & Boating | 8 | 12-08-2003 06:23 PM |
| looking for part time job | scott9 | Services & Employment | 0 | 11-29-2001 10:03 PM |
