Old 06-09-2007, 10:34 AM
mtnrat mtnrat is offline
Rep: 10 Posts: 53
Painting under rub rail?
When I get to painting my boat I do not want to just mask the rub rail. It is the type of construction where the Cap overlaps the hull and the rub rail is riveted through the cap and hull.
I will be flipping the boat and was thinking I could remove the rub rail and re-rivet the cap and hull together. Flip-paint hull-flip-paint cap then remove the temporary rivets and then reinstall the rub rail.
Would this be an acceptable procedure? I do not know if the cap to hull joint would be strong enough without the rub rail.
rope rub rails tugman Materials 4 03-17-2007 08:45 AM
Rub Rail Removal and Replacement grady Fiberglass and Composite Boat Building 11 12-03-2006 12:38 PM
Stainless rub rails SC1 Materials 0 11-25-2006 12:23 PM
New rub rail material? Deering Materials 3 03-14-2006 09:12 AM
rub rail replacement prettygoodguy11 Sailboats 1 09-23-2005 08:56 PM
