Old 06-01-2011, 10:46 PM
RochesterSS RochesterSS is offline
Rep: 10 Posts: 10
Painting Tips?
We've built a 17' boat of divinycell and fiberglass. We are looking to paint it in the next couple days and want to use a paint sprayer from home depot to get it done evenly and quickly. What kind of paint should we be using. We would prefer to buy it locally so we don't have to wait for shipping or anything. (We are in Rochester, NY)
Thanks
Old 06-01-2011, 11:46 PM
Rep: 1493 Posts: 7,447
If you mean one of those diafragm paint sprayers from Home Depot the quality is not great. If you are looking at a high gloss, a spray gun with a compressor will be better. The finish will enhance any defects on the hull. Unless it is really nice, a semigloss will hide more sins. You can use automotive enamel. An alkyd is less durable, but easier to use and less toxic.
Old 06-02-2011, 01:59 PM
Rep: 3125 Posts: 9,399
Gonzo is correct. We call these things "hand shakers", because they vibrate so much your hand is buzzing for the rest of the day. They work great when you want to change the color of the picket fence outside you grandma's garage, but really don't do much more then spit paint in the general direction they are pointed.
HVLP "pot" sprayers are better, but typically are geared to fairly heavy bodied paints (like acrylic house paint), but you can experiment with tips sizes and get reasonable results.
The real good results systems are those used be the pros. These systems are hard to justify economically, unless you have a bunch of painting to do.
Personally, I think you can get the finish of a pro job (okay darn near), just using the "roll and tip" method and high quality paint. A paint job is actually 90% prep and 10% actual brush, roller or gun in hand time, so focus on getting the surface fair AND smooth (big difference between the two). The roll and tip method is well covered in previous threads here and elsewhere on line.
Old 06-02-2011, 06:00 PM
Rep: 10 Posts: 10
I guess to clarify, we have a boat competition in four days and haven't painted or primed the boat yet. What is the quickest and dirtiest way to get this done?
We are planning on repainting after the competition, we just need something that will last us for a week.
Thanks for the help.
Old 06-02-2011, 06:02 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
"What is the quickest and dirtiest way to get this done?"
Krylon spray.
Hoyt
Old 06-02-2011, 08:45 PM
Roll it on.
Old 06-03-2011, 12:20 AM
kayant1 kayant1 is offline
Rep: 10 Posts: 14
go to west marine pettit paint looks great you can spray or roll on i like the look of spraying and yes home depot sells a spray gun you need an air compressor to do that two to three thin coats it will look like a new boat and last for years and its easy to do. good luck
Indonesia - any travel tips? Wynand N Open Discussion: All Things Boats & Boating 10 03-18-2009 03:57 AM
Captain's license, tips? mattotoole Open Discussion: All Things Boats & Boating 0 02-25-2008 01:48 AM
need tips - plywood sources 1stboat Materials 6 03-30-2006 06:41 AM
tips on spraying gelcoat? H2Only Fiberglass and Composite Boat Building 11 12-27-2005 11:39 AM
Spray painting tips Phil Thompson Fiberglass and Composite Boat Building 1 02-06-2005 11:24 PM
