Old 05-18-2006, 10:02 AM
Capt. Mike Capt. Mike is offline
Rep: 30 Posts: 24
Painting fake planking
We are refurbishing our Ta Chaio (CT42) sailboat. I want to remove the gelcoat and paint the sides with awlgrip or a similar 2 part coating, but I don’t know how to deal with the fake planking. The hull is fiberglass, but the manufacturer made it look like wooden planking by making grooves about 8 inches apart that parallel the water line. How can I remove the gelcoat, prepare the surface and then paint while keeping the planking look intact? Should I just grind down enough to eliminate the grooves and make it simple?
Most of the new paint jobs I see are Awlgrip or something similar, but I'm a little put off by its extremely high gloss. I guess I could add a reducer, but would something like polyurethane paint be acceptable?
Old 05-22-2006, 12:48 AM
Rep: 95 Posts: 462
you do not have to remove the gelcoat all you have to do is sand with 120 this should remove the gloss and wax then wash it down with a dewaxer,then prime the hull u should still have the plank lines your ready for awlgrip. awlgrip does have a high gloss but one thing with awlgrip is that if it is wet sanded and polished it will never come back to the origanal gloss so u could sand and buff to a lower gloss finsh
Painting jonw62 Fiberglass and Composite Boat Building 1 03-30-2006 09:45 PM
Strip planking vs wide planking jfblouin Wooden Boat Building and Restoration 26 08-11-2005 10:00 PM
painting over gelcoat Greavous Materials 14 12-08-2004 08:26 PM
Painting ? dansea Materials 4 09-26-2004 11:13 PM
New Painting Victor Lemmi Sailboats 0 07-20-2004 07:52 AM
