Old 06-30-2008, 03:44 PM
canoe42 canoe42 is offline
Rep: 15 Posts: 14
Painting crazed gelcoat
Well I guess patching the crazed gelcoat isn’t going to work. Too many cracks that are really impractical to sand completely out. My revised plan is to patch the ¼” hole with fiberglass cloth and polyester resin, then sand smooth. As far as the gelcoat on the canoe, plan to sand it down with successive grit sandpaper to 220 grit and prime and paint. Don’t care about the cracks, as canoe does not leak. Maine question now is what to paint it with? Thinking of automotive spray primer and automotive acrylic paint. If there are marine primers and paints that would work better please let me know.
Old 06-30-2008, 04:51 PM
the1much's Avatar
the1much the1much is offline
hippie dreams
Rep: 625 Posts: 3,931
all marine paints and primer will work better,,,,but ,,if your not fixing the cracks,,then why waste the money on marine paint,,,,,,,its just fine to use auto paint if your not looking for it lasting,,,and even if you want it to last,,,auto paint should stay on a canoe for 10 or so years
hehe ,,,,,Jim------>
Old 07-02-2008, 07:34 PM
Kaptin-Jer's Avatar
Kaptin-Jer Kaptin-Jer is offline
Semi-Pro
Rep: 206 Posts: 572
As long as the cracks are only gel coat crazing you can fill with a glazing putty then sand and fare down to 320. If you are going to go through the trouble and expense of spraying auto paint you should go the small next step and spray Awl Grip. Canoe paint gets even more abuse then a typical boat at a marina, so go for the better paint. A pint kit should give you about 5 coats, but I defer to JIm. He is the spray Guru.
Old 07-02-2008, 08:21 PM
the1much's Avatar
hippie dreams
ya it should be 5 coats,,more or less depending on how ya spray.
what do I do next before painting??? newbie101 Fiberglass and Composite Boat Building 5 06-03-2006 08:12 PM
Painting jonw62 Fiberglass and Composite Boat Building 1 03-30-2006 08:45 PM
Spraying gelcoat over gelcoat alexhiguera Fiberglass and Composite Boat Building 9 08-26-2005 10:09 PM
painting over gelcoat Greavous Materials 14 12-08-2004 07:26 PM
Painting ? dansea Materials 4 09-26-2004 10:13 PM
