Old 02-20-2011, 10:24 PM
Steve W Steve W is offline
Rep: 360 Posts: 686
Paint shaver pro
Any of you guys using this tool made by American International Tool Industries? Its also marketed as the Marine shaver pro. Im looking for a reasonably priced tool for removing the gelcoat and skincoat on the bottom of a a 26ft boat that will do the job easier than a grinder. It seems that the only handheld tools available are this tool or the gel planer which is a lot more expensive. If anyone has any other recomendations of a tool im not aware of (other than a grinder) i would appreciate it.
Steve.
Old 02-21-2011, 06:06 AM
Rep: 670 Posts: 2,457
I haven't seen a gel coat peeler in action for years. Seems all the yards prefer to sandblast. They tell me the gear is more versatile and does a better job. Unless you need a peeler for a special application you might speak with the local marine sandblaster and inquire about his capabilities..
Old 02-21-2011, 06:08 AM
Rep: 1493 Posts: 7,447
I find sandblasters to be easier and faster to use. With the planers, you have to grind the spot you can't reach.
Old 02-21-2011, 07:39 AM
Rep: 360 Posts: 686
Thanks guys, over the years we have bith hired sandblasting contractors to do the job and rented the equipment and done it ourselves and while it works ok for a big job i find it a bit of a production getting set up for a smaller job by the time we tent everything off to contain the dust, mask off, pick up the equipment, pick up the blast media, do the job,then return the equipment clean up and dispose of the mess etc, the actual blasting is the easy part. The boat i need to peel is my own 26ft sailboat which is in my yard, not at the shop and i would like to be able to do it a couple of hours at a time in the evenings which precludes renting sandblasting equipment. Also i would like to reduce the mess, so, i would like to hear from anyone who has actually used one of these tools, who can tell me the pluses and minuses, if they work as well as the videos show,how long the blades are likely to last etc. I must say both the tools i mentioned look pretty impressive in the videos on their respective websites.
Steve.
Old 02-21-2011, 08:53 AM
SamSam SamSam is offline
Rep: 502 Posts: 1,684
Post a link.
All Pro Ho's goodwilltoall Open Discussion: All Things Boats & Boating 7 10-16-2010 07:45 PM
Workshop Pro... jimianbu Software 0 10-03-2010 03:25 AM
Pro-B (Pro-A sailplans/hullplans???) bearflag Multihulls 5 06-30-2010 02:50 PM
To paint or not to paint over 3m 5200 BurnabyRocket61 Materials 3 09-01-2008 08:45 PM
Pro-E Designer arckrk Services & Employment 3 01-22-2007 06:33 AM
