Old 01-09-2006, 07:52 PM
MilitaryPopo MilitaryPopo is offline
Rep: 10 Posts: 28
paint question
is there any important difference between top side paint and regular auto paint? what i'm asking is if i repaint my topside with auto paint and then put clear top coats (also auto) to seal it, would that work? this is on a 21 ft fiberglass speedboat
Old 01-09-2006, 09:00 PM
TimClark TimClark is offline
Rep: 31 Posts: 110
Auto paint works best on types of metal and materials of the sort...I would just go to a West Marine and pick up some Interlux top-side paint, I have always used it on my fiberglass and wooden boats and it works great. Good Luck.
Tim
Old 01-10-2006, 01:31 PM
jimslade jimslade is offline
Rep: 14 Posts: 304
The only (automotive) paint that will work would be Urethane. You first have to use an epoxy primer to seal off the gelcote. Most clear coats are urethane based. The only problem is that Urethane needs to be sprayed to be applied properly and is dangerous to work with. It should only be applied in a spray booth. There are some epoxy paints that can be applied by hand but will not give you the results of sprayed urethane.
Old 01-10-2006, 04:40 PM
rturbett's Avatar
rturbett rturbett is offline
Rep: 22 Posts: 139
I have had great luck with interlux topside enamel with teflon. I have had awful results with interlux toplac
Old 01-11-2006, 10:47 AM
boatbuilder.org boatbuilder.org is offline
Rep: 10 Posts: 54
I have used automotive paint in the past with great success. I Use a two part epoxy primer over the hull and then have gone over that with a two part PPG paint called Concept DCC. No need to clear coat over it.
---Joel---
Old 01-11-2006, 07:49 PM
ondarvr ondarvr is offline
Rep: 226 Posts: 636
Good automotive paints work very well as topside paints, there is no problem in using them, plus you can get it in any color you want. There is no need for a primer when painting with them over gel coat unless there are surface imperfections that need to be filled. Clean sanded gel coat is a very good, if not better than primer, surface to for paints to bond to.
Old 01-29-2006, 04:46 AM
mastcolin mastcolin is offline
Rep: 96 Posts: 89
Auto paints(the 2 pack polyurethanes) are not as hard as the marine equivalents but unless you are going to leave fenders over the side or bang it around, they do job.
Big plus is price normally and colour choice. Also probably easier to spray. Put plenty on, ideally with clear. It will give you something to buff later in life.
I'm not necessarily agreeing with "no primer needed" comment. You're better giving the grp a good sand (with say p150grit) then apply sand this finer (p400). If you apply the topcoat to the grp direct you can only use finer grades or the scratchmarks will show.
I also suspect the boat is old so will be a little bashed about. The primer will fill the minor faults - and highlight some you won't see till you paint eg fine starcrazing, pinholes
Old 01-31-2006, 08:44 PM
wdnboatbuilder's Avatar
wdnboatbuilder wdnboatbuilder is offline
Rep: 15 Posts: 227
I used PPG auto paint on my boat with an epoxy high build primer underneath. Been a great have had no problems 3 years into paint job.
Calm days, Tides Running, and Fish Biting
What more could you ask for?
Bruce
Old 01-31-2006, 10:07 PM
Rep: 95 Posts: 462
Go with algrip its a urathane and is made for the marine and aero u can have a additive put in to it to allow more flex in the paint
Boat Floor Paint.. ahasiec Fiberglass and Composite Boat Building 2 01-05-2006 01:26 AM
Topsides & Deck Paint Question Chris Krumm Materials 3 08-27-2005 08:44 PM
Antifouling Paint Question - ViViD TennesseeGuy Materials 1 05-31-2005 01:31 PM
Paint question over epoxy zember311 Boatbuilding 5 11-26-2004 03:22 PM
Help PAint or gel this is the question Bayliner bum Materials 1 09-10-2004 01:37 AM
